Sponsored by Discount Tire |
rim and tire ?? for a 08 f350
i am looking at the incubus nemisis 20's and dont know what thew bigest tire i can fit on it. (widest and tallest) and what offset i need to have it stick out from the fenders a little bit, not crazy so it takes my paint off
.. thanks guys
Run the +10mm offset and a 295/60R20.
that offset will make them stick out a little bit? and if i were to go with a 22 what size tire would i need? thanks for the info!
Both the 20x9 and 22x9 sizes come with either a +10mm offset or +25mm offset. The lower the offset, the more the wheel will push out towards the fenders. The +25mm offset mounted with the 295's will sit flush with your fenders. The +10mm offset will set the wheels outside of the fenders by just over 1/2", not including the tire.
There are currently no LT - 22" tires produced that will fit your application without a lift. I recommend sticking with the 20" wheel and tire combination -Matt Last edited by Discount Tire; 06-21-2010 at 01:29 PM. |
sweet thanks alot!
