ABS Light on, Not working - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 06-19-2010, 08:04 PM
ABS light came on out of nowhere, and tested and sure enough full lock up. ABS not functioning at all. I was curious if anyone could help me out? I tried the code scanner I have but it seems to only grab engine codes.
Old 06-19-2010, 08:36 PM
ADMIN AND TECH
abs module will have codes also, you will have to get it on a scanner thatwill pull them
Old 06-19-2010, 08:47 PM
Would assume that autozone would not have something like this? Makes no sense to me why brakes would be perfectly fine (abs functioning normal) and then no abs at all. Excursion is one big sled when its sliding
Old 06-19-2010, 09:11 PM
My Auto Zone dosent.
Check all fuses and brakes, Wheel bearings and it sounds weird but even ball joints.
Old 06-20-2010, 11:24 AM
also check the sensor in the reaerend. mine gets dirt in the connector, i unplug it clean with contact cleaner and put it back on. i have to do this about once every oil change, since i live on dirt roads.
Old 06-20-2010, 11:37 AM
need to find somone with a scanner that can run it under usa domestic and scan just the abs system and pull the codes off most shops have a scanner with this capability but just need to find one that will scan it and not charge you arm and let to scan it.
Old 06-25-2010, 04:41 PM
Feedback Score: 5 reviews
That's exactly what mine was. The rear ABS sensor that mounts above the pinion on the rear end, is also your vehicle speed sensor that works with your cruise control. My ABS light was coming on at random times when my sensor went out. I figured it had to be the rear one because if I was on the highway with the cruise control on, and the ABS light came on it disengaged my cruise control. So that let me know it had to be the rear one. Picked up another one and changed it out....no more ABS light.
Old 06-25-2010, 05:44 PM
My abs light stays on speedo and cruise are fine
