Rear brakes - repair info needed - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 6 Old 06-15-2010, 06:34 PM Thread Starter
TxFireman1972's Avatar
Feedback Score: 6 reviews
Had a right rear brake caliper come apart on me this evening. Won't know exactly what all is screwed up till I tear it all apart. Looks like either the caliper piston broke or the seal failed on it. Tore up the rotor, not sure how bad the caliper is.
To the best if my knowledge, I don't think I have ever done rear disc brakes. Anything special I need to know when installing new rotor, caliper, and pads? An special tools required? Thanks in advance.
2005 F350 Crew Cab 4x4
PMF Rear Leaf Spring Conversion w/2011 Leaf Springs
20" Harley Wheels 305/55/20 Nitto Terra Grapplers
ARP Studs & EGR Delete from PowerStrokeMagic w/GearHead Tunes
Amp Research Steps, MBRP
"Two in the heart, and one in the head, I don't like repeat offenders, I like dead offenders!" -- Ted Nugent
TxFireman1972 is offline
post #2 of 6 Old 06-15-2010, 07:10 PM
No special tools are required. I cant remember the socket sizes of the top of my head but rear brakes on these trucks are very easy.
Two bolts to remove and the caliper comes off. Another 2 bolts to remove the caliper mount bracket and you will be able to remove the rotor. If you have to replace your caliper there is a standard banjo fitting with two copper washers. It is good practice to replace those copper washers when installing the new caliper. I dont think it is absolutely necessary but its up to you. Also make sure you lube up the slide pins on the caliper well when you reinstall it.
-Aaron
2005 Ford F350
SCT X3
Isspro Performax Gauges
Dieselsite Boots
Fumoto Oil Drain
Coolant Filter
MBRP Dual 4" Straight Pipe
Harley Headlights
Pioneer In Dash GPS
6000K HID Headlight and Foglights
Smoked Lights
6.0DSLPWR is offline
post #3 of 6 Old 06-15-2010, 07:18 PM
05charcoal6.0's Avatar
Send a message via AIM to 05charcoal6.0
x2 to what 6.0dslpwr said. I would also like to throw in that when you lube up the slides for the caliper use slide pin lube and not the brake pad lube. the brake pad lube will just deterioate unlike the slide pin lube. I'd hate to see someone do the job twice because the caliper doesnt slide and causes problems down the road.
2005 F-350 Extended Cab Short Bed 6.0L
4" Superlift lift
Homemade Traction Bars
MBRP 5" Straightpipe w/ 6" tip
Toyo Open Country mt 35-12.5-20
XD Monster 20x10
Custom Interior
Recon Lights
Train Horns
Banks Intercooler
Volant Intake
RCD Full EGR Delete
SCT-ID Extreme Race - dd
Autometer 4 Gauge Pod
Ultra-lites Boost Pyro Trans Water Fuel
Fuel Press(mounting cup)
Trusted Performance Stage 1 Fuel Lines
Airdog 2
Soon to come:
whatever the wallet can buy
05charcoal6.0 is offline
post #4 of 6 Old 06-17-2010, 08:34 AM Thread Starter
Found the problem, time to go get parts. Any suggestions on pads? I may just have to put something on from the parts house for now. Would like to do Hawk pads, but no time to order good ones.
post #5 of 6 Old 06-17-2010, 08:57 AM
I have the hawks right now on factory rotors and im really starting not to like them. I know the monroes are good or just the regular ford pad is what i might go to. But i know other people that like the hawks but im just giving my two cents from my own experience.
4" Superlift lift
XD Monster 20x10
Custom Interior
Recon Lights
Train Horns
Banks Intercooler
Volant Intake
RCD Full EGR Delete
Airdog 2
Soon to come:
post #6 of 6 Old 06-17-2010, 03:09 PM
So far I have only changed the front pads on my truck once. I went with napa pads because I was in a hurry and that is all they had in stock. I absolutely hate them, they are the worst pads ever.
If you guys find any good pads let me know. I was thinking about trying the hawk pads or maybe those EBC pads you see advertised in all the magazines. Only problem is I will need to order them before I actually need them to allow for shipping time. If all else fails I will go back to raybestos pads. Used them many times in the past and never had a problem with them
-Aaron
2005 Ford F350
SCT X3
Dieselsite Boots
Fumoto Oil Drain
Coolant Filter
Harley Headlights
Pioneer In Dash GPS
Smoked Lights
