Cannot remove wheels - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 05-28-2010, 07:07 AM
06 F-350 with factory aluminum wheels. Tried to rotate tires and the wheel is stuck on all hubs front and rear. It appears that the wheel holes are galled to the hub. Is there away to get them off without damaging the wheel?
Old 05-28-2010, 07:26 AM
take a sledge to the tire from the back side and beat on the tire and spray the hubs down with pb blaster or other penetrating oil. then when you put them back together use some antisieze on the hubs first.
Old 05-28-2010, 07:47 AM
Yea, they're designed that way. Hubcentric.
Mark
Old 05-28-2010, 07:49 AM
What they said ^^^
Old 05-29-2010, 04:40 AM
Chapter Director
Yeah, I had to do that when I went to rotate mine last time. Believe me, We had to beat the crap out of the back of the tires with a sizeable sledge to get them off.
Old 05-29-2010, 05:51 AM
when you get them off, if you can, put a little never seez on the hub. that will prevent this problem in the future.
Old 05-30-2010, 06:04 PM
Loosen the lugs a couple of turns and drive the truck forward and backward a few feet and stab the brakes while moving. If the problem is with the front, turn the wheel while doing this.
Old 05-31-2010, 12:00 PM
Sounds like they painted the hubs and then put the wheels on with out drying.
Old 05-31-2010, 01:35 PM
as stated above. its called galling and its corrosion that happens between steel and aluminum over time. beat em off like mentioned above and antisieze the hubs every time you rotate. shouldnt have anymore problems after that. same thing goes for when your putting steel bolts in anything aluminum. MAKE SURE you put antisiece on them. or risk stripping out a bolt hole. it also helps to put antisieze on all of your wheel studs to prevent your lugs and studs from rusting together.
