Sponsored by Discount Tire |
Max load vs. load rating?
OK, so I don't claim to be an expert, but I thought that pretty much any tire load rated for over 3000lbs was load range E? Case in point, take a look at the link below. In particular, the tire sizes 315/75R16 and the 35x12.50R17. Both are load rated at 3197lbs, and very close to being the same size.
General Tire - Off-Road and Performance Tires - The Tires - Light Truck So, here are my questions: 1. Am I wrong about a tire rated at over 3000lbs always being a load range E tire? 2. If I am wrong, WTF is the difference that allows 2 tires of almost the same size, and the same load rating to be classified differently? 3. How can one size tire load rated at 300-400lbs less than the same tire of the same rim size, be a load range E, when the higher load rated tire is a D? See tires in the 16in rim sizes here: General Tire - Off-Road and Performance Tires - The Tires - Light Truck Long post, I know, but everything I thought I knew is all jacked up. |
I've wondered this as well. All I can think of is the number of plies in the tire being different?
I'm fixin to get some 40" Procomps that are Load range E and are rated to like 4675 lbs per tire. Wondering if they're gonna jar my teeth on the road but couldn't pass up the deal. |
