Sponsored by Discount Tire |
lubing slide pins ?
i'm right into changing the front pads on my 06 f350 dually ... is the slide pins the 2 bolts with the dust covers that screw into the side of the caliper? if so , do i just remove them , lube , and replace ?
Yes, and make sure they move freely. I use anti-seize to lubricate.
Yes, that would be them. Lube them often...
while your at it, its a very good idea to change the break fluid. The fluid is hydroscopic and attracts water. And never use fluid from a bottle that has been use already and put back on the shelf. |
thank yall for the info , i'll get back to work on it now...
mike |
I recomend cleaning out the holes that the sliders go into with some brake cleaner and a rag. I used a thin rag to clean mine out and got a bunch of junk out of there that was caked to the walls. Just used the back end of a long wood q-tip to push the rag in and move it around. My sliders were pretty bad though, one was frozen in blace and I had to beat it out with a 3lb sledge against an open-end wrench wrapped around the pin head.
Also make sure you pay attention to which slider goes in which hole. They are different, top and bottom. |
slide pins
front brakes done !! thanks again for the quick response and the willingness to share knowledge with us "saturday morning mechanics"!!
why did your slide pin holes get so gunked up ? did your dust boot crack or what ?
