hole in rim - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 05-04-2010, 07:43 PM
hole in rim
had a low tire, brand new tires and took it to discount and found a small hole on the inside of rim?? how does this happen, here goes another $250 for a new rim
Old 05-04-2010, 07:46 PM
BOSS LEVEL
steel or aluminum?
Old 05-04-2010, 08:21 PM
Warranty or have them repaired.
Old 05-05-2010, 06:55 AM
they are aluminum
Old 05-05-2010, 07:36 AM
deflate tire, fill hole with high quality epoxy and go on with life...well, I did anyways for a while after I discovered a pinhole leak in a rim. The best idea, no, but it'll work at least short term. Don't inflate the tire for a day or so to give it ample time to cure. If you could take out the valve in the stem you could vacuum the epoxy into the hole.....never thought of that til now.
