Tire blow out over the weekend (8" lift/37" tires/ 22" wheels)... - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 13 Old 05-03-2010, 03:05 PM Thread Starter
WydOpen's Avatar
Send a message via AIM to WydOpen
I was driving about 70mph down I-64 in Newport News, VA on Sunday heading to Williamsburg and was on the phone. I heard a weird noise coming from the bed of the truck on the driver's side, but didn't feel or notice anything different about the truck (handled fine and kept driving straight).
About 30 seconds later a couple in a Suburban comes alongside and starts honking and waving toward my left rear tire. I pulled off the interstate and hopped out of the truck and low and behold the tire was flat. I was amazed that I didn't feel any difference in how the truck drove or felt. I honestly didn't notice the attitude with the left rear lower than the rest of the truck. I always thought if I ever got a flat in my truck it would be very pronounced...not so!
Though not my first time changing a flat, it was the first on a Super Duty and first on a big jacked up truck. I'm lucky that just three days ago I had the common sense to throw the lug nut key in the center console (dealership reminded me when they couldn't rotate the tires or check the brakes during the 75,000 mile service). Found the jack and tools behind the seat, but didn't realize the spare has a special key! Found that in the glove box and wrestled with the rod to lower the spare.
FOR THOSE WITH LIFTED TRUCKS...I highly suggest throwing a block of wood or something behind the seat with the jack and tools!!! I had to lift from the bottom of the differential just to get the jack to reach (my Hi Lift is now permanently in the bed). While you're at it, throw a set of gloves in there too!!! I was in shorts, a polo shirt, and flip flops and I left my gloves in the garage the last time I helped a buddy move. Also, for those with aftermarket wheels and different than stock lug nuts, keep 8 stock lug nuts in the truck with that block of wood and gloves. You'll need them to run the spare wheel!
The emergency jack worked surprisingly well. I need a better tire iron, though. I usually keep a Gorilla wrench in my vehicles, but haven't gotten around to it with this truck. I was luck when putting on the new wheel. Just as I got the spare on the truck, I gave it a nudge with my knee to seat it against the hub and the truck fell off the jack! Had to jack the truck back up and get the spare reset on the hub. That was a little scary.
Just a personal experience and some lessons learned while changing a tire with a lifted truck.
Oh yeah, the fix was quick and inexpensive from the local tire shop I bought the wheels and tires. I was in and out in about 30 minutes after they threw a patch on the inside. The salesman said the patch was free, but I gave the guy who did the work a $20 for the quick job and putting the tire back on the truck and putting my spare back underneath. They have a repeat customer! If the patch didn't work I was looking at about $550 for a new tire.
- Rob
2015 Tuxedo Black F250 CCSB Platinum FX4 6.7L PSD
PMF 2.5" Alpha Series | Fuel 22x10 Mavericks | Nitto 325/50-22 Trails | Edge CTS2 | AMP PowerSteps | RetroShop Headlights
WydOpen is offline
post #2 of 13 Old 05-03-2010, 03:23 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
glad to hear that
good customer service goes a long way.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #3 of 13 Old 05-03-2010, 03:39 PM
Michael707's Avatar
that sucks, i have a tool box in the bed of my truck with a buncha tools n ish for freak situations like that. weird that you couldnt tell the diff
96 7.3 PSD
240,000 miles
diesel innovations chip
11 inch lift that eats my 38s
basically a rolling cloud
Michael707 is offline
post #4 of 13 Old 05-03-2010, 04:29 PM
KYmxracer52's Avatar
Thank goodness the flat went smoothly. I've heard of them exploding and causing a bad wreck. That's always my worst fear when traveling.
2005 F-250 CC SB-SCT,Edge Insight,5" MBRP, 5" ProComp lift, dual-stabilizers, 35x12.50 Federal Couragia MT, 20x10 Fuel Hostages, B&W ball, Truxedo roll cover
KYmxracer52 is offline
post #5 of 13 Old 05-03-2010, 07:33 PM Thread Starter
WydOpen's Avatar
Same here, that is what I was worried about. It scares me that I didn't even know the tire was flat. My wheels and tires were expensive and had I continuted driving it could have been a $1,000+ mistake.
But, now I know what a 37" tire sounds like when it loses air through a puncture. It sounded like a blow off valve from a turbo. I thought at the time an import was letting off the gas behind me and making the noise.
- Rob
WydOpen is offline
post #6 of 13 Old 05-04-2010, 02:44 AM
Cutty72's Avatar
Quoted: 11 Post(s)
Not sure how far you had to drive like that, but it can be hard on your rear diff running two different diameter tires like that.
'01 F250 Lariat Crew Shortbed
Tunes by Swamps
4" Turbo back MBRP w/ muffler
GTP38R
6637 intake
3662 Maintenance Company Supply NCO
Cutty72 is offline
post #7 of 13 Old 05-04-2010, 03:43 AM Thread Starter
WydOpen's Avatar
That was on my mind constantly. My speedometer was way off compared to my GPS. Altogether I probably drove it about 50 miles with the spare. I didn't want to, but didn't have much of a choice.
- Rob
WydOpen is offline
post #8 of 13 Old 05-04-2010, 03:57 AM
mcflan's Avatar
Feedback Score: 9 reviews
Glad you're ok and that everything worked out!
Jon
03 6.0 F350 SD
SCT w/Matt's SRL
Zoodad
AFE Stage II
EGR Delete
Banks Monster Exhaust
Isspro Gauges
Studded, Lapped, and Bored
175cc Injectors
Powermax Turbo
Blue Spring FPR
Diesel Site Coolant Filter
AD2 Fuel System
Oil By-Pass System
My personally made Remote FICM/Board
mcflan is offline
post #9 of 13 Old 05-04-2010, 04:48 AM
thesmokinstroke02's Avatar
yeah i need to put 8 of my stock lugs in my truck too. im thinking about getting a toolbox and getting a dang 3 ton jack and keeping it in there lol. i dont trust bottle jacks as it is.
Konnor
2011 Cruze
R.I.P. Will Iott
thesmokinstroke02 is offline
post #10 of 13 Old 05-04-2010, 04:54 AM
mcflan's Avatar
I couldn't agree more. The bottle jack terrifies me when I have to resort to using it. It seems like it's orribly unbalanced imo
Jon
03 6.0 F350 SD
SCT w/Matt's SRL
Zoodad
AFE Stage II
EGR Delete
Isspro Gauges
175cc Injectors
Powermax Turbo
Blue Spring FPR
AD2 Fuel System
Oil By-Pass System
mcflan is offline
