Sponsored by Discount Tire |
bfg at mix size
im about to receive some fairly new bfg at tires. but they dont match in size.
one size is 235/85/16 and the other are 265/75/16. truck thats it is comming off is a 88 f350 on steel rims and its a 2wd they are going on my 1999 sd f350. i am going to put the 265s in the rear. the question is can i put the 235s on the front or the sd rims are too narrow for that. the other thought was to put the 265s in the front and put new 265s in the rear. or put 285/75/16 in the rear. i know the 285s are an inch difference in hight, but is that ok for the 4x4 system when using it? Last edited by Jarrod B; 05-02-2010 at 11:14 PM. |
i wouldnt mix tires dude. thats just mo
i was tryin to avoid that. but im only in 4x4 off road. i really want 285s all around but this changed that plan atm. eventually it will get done.
idk what kind of condition the tow other sized tires are in, maybe go down to les schwab bro and ask them if theyd accept those used tires and give you a deal on two other ones of the same kind you need? unless your broke a fudge that is lol
the tires on my truck? they are uniroyals liberators. half tread left and they would be goin on the other truck for the swap.
