Sponsored by Discount Tire |
smallest rim size?
ive got a 2006 f350 lariat and was currious if anyone knew what the smallest size rims i can fit on it
You are going the wrong way! Did you mean what is the biggest rim you can fit?
Are you trying to fit some rims from an older PSD?
Someone can chime in, but with the 06, 18" is the smallest you can go due to the brakes. |
I use to have aftermarket 16's on my 04 but It looks like 16's won't fit on this truck
2005 and newer must have at least 17" rims to fit over the brake calipers.
And check carefully if you are going to use aftermarket 17" wheels because I have read that some of them won't fit. |
Ok, thanks
