Sponsored by Discount Tire |
How to determine offset needed
I have a 2004 f250 with a 2.5" leveling kit. I currently am running 305/70/16 on stock rims and have clearance still. I want to run 18x9s with 35s. How do I determine what offset I need?
4.5".......
Shoot for a -6 to a -10mm on a 9" wide wheel. Some modifications will probably be needed.
-12mm on a 9". I have 33x13x18s, with an 18x9 wheels with 4.5" backspace (-12mm) and I rubbed without trimming my lower valnce and zip tying the fender walls back.
thanks
Thank you everyone.
i have a 2004 f250 i wana lift it 4 inches with 35x12.50 what is the offset i can get to have the tires stick out as far as possible without them rubbing i would like them to stick out like 2 inches but idk if thats possible without a higher lift
With a 4" lift shoot for a 9" wide wheel with a -12mm offset. If you go with a slightly shorter tire you could run a 10" wide wheel with a -25mm offset (without rubbing).
I'm putting a 6" lift and I plan on getting 22x9.5 with 37s. What offset would be best? I'm a retard when it comes to tires and wheels. Lol
Most 22x9.5" wide wheels are going to have a -12mm offset (4.75" BS). What year and model truck for you have? |
2008 f250 4x4
