Sponsored by Discount Tire |
the perfect off set for my 2000 F250 4x4??
i am in the search for rims online and was wondering what offset and what width size will work best for my truck. i want it to stick out a little for my 6 inch lift...... any suggestions ??
I just ordered some 18x9 wheels and 35/12.5 tires. The wheels have 5" backspace and they said they will stick out about 2"
that sounds like a great look . but the problem with me is that i was told that my year truck has a more of a negative off offset then the newer ford. unless someone can correct me! |
Where ever u buy from should be able to tell you what offset u need for your truck to get the look you want.
around -20 offset would look good
4.5" backspace is perfect!
On a 9" wide rim, it would equal -12mm offset. On a 10" wide rim, it would equal -25mm offset. |
would that stick out just bit on my year truck compare to the 6.0s??
I have a 2003, so it's no different suspension than yours
But yes, mine sticks out, but it's pretty. I am running some fat tires also, 33x13.00x18s.
thank you it looks great just what i wanted!!!
