Who has BMF's, 35 or bigger Toyos and TPMS? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 12 Old 04-16-2010, 02:03 PM Thread Starter
Blk04Snake's Avatar
I'm looking for anyone that has BMF Wheels on their truck with 35" or bigger Toyo M/T's and truck is equipped with TPMS... Running into issues and I just am hoping to rule out the wheels as the cause of the problems I'm having. I know the tires aren't at fault because I used them on my first truck with the TPMS and it functioned as it should.
Thanks.
2010 F250 Lariat CC/SB, Icon 2.5, 35s on 20s, Spartan, AFE 4" SS Downpipe back. RIP 1/13/10
2010 F350 Lariat CC/SB BDS leveling kit, BMF, Toyo, Recon, N-Fab, Spartan, AFE, Flo-Pro, MBRP
Blk04Snake is offline
post #2 of 12 Old 04-16-2010, 03:00 PM
navydocsuperduty's Avatar
ive got 20x10 Novakane 8s and 35x12.5 Toyos and no problems here.
17 F350 Lariat CCLB
08 F350 Lariat CCSB, DPF/CAT Delete w/ 5" back, S&B, SCT, Recon;Cab, Mirror, and Line of Fire, Black Emblems, BMF 20x10 novakane w/37x13.50 Toyos, 2.5 Icon Kit, TEI, 5" rear blocks, Top Gun dual steering stabilizer, AMP Steps, Line-X Bed, Diamond Back Tonneau, T-Rex Black Billet Grill, Nathan P-3 w/ onboard air, High Idle Mod, Titan 51 Gal Tank, BFxenon HIDs SOLD
navydocsuperduty is offline
post #3 of 12 Old 04-19-2010, 07:17 AM
38s with 20 sotas and throwing the tire pressure sensor fault after about 100 miles of driving.
2009 F250 CC/LB 4x4 6.4 Sterling Grey
AFE Stage II PG-7, Spartan with 310 and tcm, dpf/doc and magnaflow exhaust, 6k hids fogs and low/highs, Custom Rize 11 inch lift with fox coilvers and atlas springs, custom traction bar and BMF SOTAs with 38 inch toyos
sdcarguy is offline
post #4 of 12 Old 04-19-2010, 11:16 AM Thread Starter
Blk04Snake's Avatar
Being an 09 you should have the band sensors.. I'm just wondering if since the bigger M/T tires are beefier than the OE Continentals and Goodyears that the sensors have a little bit of a harder time transmitting thru the tires.. Anyone else care to chime on this?
post #5 of 12 Old 04-19-2010, 12:01 PM
yep i have the bands and bought all new tpms and bands for the sotas. I am going to try to train them and see if it helps but I have to buy a trainer first...
sdcarguy is offline
post #6 of 12 Old 04-24-2010, 12:43 PM
Hey man just fyi...I went and had discount train mine and it cleared the tire pressure monitor fault instantly...the low pressure came up in 2 miles cause they are only at 38. I talked to my friend at ford and he think he can reset the sensors down to 35psi...ill be trying that to. Dont forget I do have the band sensors...
sdcarguy is offline
post #7 of 12 Old 04-24-2010, 01:00 PM
smotrs's Avatar
Most of the Toyo MT's have a rating of 65PSI, take a look at the pillar sticker inside the drivers door and see what your truck requires. If the PSI matches the tires, then all you have to do is transfer the Sensors into the new tires and your fine.
If you lower the PSI below the allowable threshold, then it will trip the TPMS warning lights and messages. So play around with the pressure until you find the happy spot.
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT's
Avic-Z2 Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, Six-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares
Ravelco Anti Theft Device
Originally Posted by Rick Santorum
We went into a recession in 2008 because of gasoline prices.
smotrs is offline
post #8 of 12 Old 04-24-2010, 04:06 PM
wired1's Avatar
blk04snake the f350's run 65 psi F and 80 psi R thats where the problem comes from for us f-350 guys. on my 09 discount used a valve stem mount instead of the bands for the tpms and it works great. the only thing is i have to run 70psi or better in the rear to keep my light from coming on. also how do you like the bds leveling kit vs the icon you had on your old truck?
2013 F150 FX4 EcoBoost fully loaded with the app pkg on Icon 2.5" coilovers
06 F350 Lariat-PMF 8" on 37'sSold
09 F350 ccsb Pmf 7" on 37's Sold
01 F250 ccsb 6" on 35's with to much to list Sold
98 Cobra Vert 583 RWHP Sold
wired1 is offline
post #9 of 12 Old 04-24-2010, 07:27 PM
Michael707's Avatar
38 inch toyo mt's
Michael707 is offline
post #10 of 12 Old 04-25-2010, 07:22 AM Thread Starter
Blk04Snake's Avatar
Everyone keeps saying about the pressures 65 front and 80 rear... That IS NOT the problem I'm having. First the truck has to recognize the sensors before they can tell me the pressure is too low. My message is "TIRE PRESSURE MONITOR FAULT" which according to the service literature means that the truck is not seeing any of the 4 sensors in the tires. I've tried the training procedure using both the activation tool and the trick of lowering the tire pressure until the horn honks. Neither of these is working.
