Brake caliper slider pins - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 1 Old 04-14-2010, 07:06 AM Thread Starter
Glenn M's Avatar
I had the good old Super Duty front end shakes while braking.
I replaced the brake caliper slider pins & boots on all four wheels Yesterday.
I had a few that were pretty stiff and one rear pin that was stuck.
I bought Federal Mogul brand from Advance Auto for $52 OTD, best price I found on any brand or place.
I pulled the brackets off and polished the pin bores with a little flapper rod I made up with some 400 grit paper.
Lubed them up with Valoline silicon brake grease.
Torqued the lug nuts to 160lbs.
I did nothing but change the pins and the shakes are all but gone.
Glenn
The only time it ends, is when your pockets are totally empty!
2001 4x4 F-250 SD,SC,SB, Lariat, PSD, HX cross over, DT466 cps, Ford AIS intake, 4" Pinnacle pipe, built trans, Dacco 3disk converter, Isspro pillar gages. MAP reg., ZooDad Mod,TS 6-pos chip,Truxedo/Plus Tonneau.
Glenn M is offline
