what size will fit - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 17 Old 04-12-2010, 11:48 AM Thread Starter
6.0way2go's Avatar
what size will fit
2003 f-250 fx4 ,alright does anybody know what size tire i can fit ,4 inch pro comp lift ,i see guys using level kits for 35s ,can i run 37s im not sure need an idea ,tires i want use are dick cepek fc 2s or toyo open country mts thanks
6.0way2go is offline
post #2 of 17 Old 04-12-2010, 01:57 PM
You should have no problem running 37"s with a 4" lift but keep in mind that with such large tire your speedo will be off somewhat and your def gonna wear out your suspension and put excess wear on your tie rods, ball joints, tranny.. etc You can't just throw huge tires on a stock driveline without it wearing prematurely!!
97F350Diesel is offline
post #3 of 17 Old 04-15-2010, 07:24 AM Thread Starter
6.0way2go's Avatar
thanks dude ,i think im going with 375/65-16 mickey thompson atz
post #4 of 17 Old 04-15-2010, 07:29 AM
big sig's Avatar
Put some info in your sig. I have a 6 inch on my 2002 and it would be hard for me to run 37s without trimming my bumper. But I have a friend with a v10 and he runs 37s with a 4 inch lift. I think it all depends on the wheel. What are you running now?
mine
2002 F250 7.3l Powerstroke
AFE Stage 2 Intake
MBRP 4inch Turbo back exhaust straight piped
Autometer gauges z-series pyro, boost, tranny temp
PHP F.U. Chip
4 inch rough country lift, 315/75/16 mud grapplers, and procomp 1069 16x10
dads
2011 F350 SRW CCSB KR 6.7l Powerstroke
FB: Tyler Sigmon
big sig is offline
post #5 of 17 Old 04-15-2010, 07:31 AM Thread Starter
6.0way2go's Avatar
got another ? ,runnin 5-40 full syn. now that warmer weather is here should i switch to 15-40 what everybody think tryin to get in the click here thanks
post #6 of 17 Old 04-15-2010, 07:32 AM
Raul@Stealth Automotive's Avatar
well... all depends on the offset of your wheel.. you could prob squeez 37's on a 4" lift but its going to rub... how wide is the wheel your going to put on it?
-Raul
Raul@Stealth Automotive is offline
post #7 of 17 Old 04-15-2010, 07:38 AM Thread Starter
6.0way2go's Avatar
the guy who had it before me ,has 285/75 -16, he was an older guy in his 60s .they look really small .im think im going with 375/65-16 they are 35 n half by 14.50 wide i should be alright,workin on info and pics
post #8 of 17 Old 04-15-2010, 07:40 AM Thread Starter
6.0way2go's Avatar
-Raul
its a wide rim im thinkin 10 inch
post #9 of 17 Old 04-15-2010, 07:44 AM
your more than likely going to rub... i rubbed with 37's on a 8" lift..... if your ok with rubbing then go with 37's if not go with 35's
post #10 of 17 Old 04-15-2010, 07:58 AM
big sig's Avatar
I had 35x12.50s on with a leveling kit and i rubbed like crazy. get out the tape measure and see how much room you have all around. I would always go on the small side of what you think you can do so you dont ever rub. I know now if im turning and go through a ditch itll rub the bumper. Do you know what backspacing you have? and about the oil. I always get mine serviced at the dealer so im not sure what they put. I put 15-40 in all of my diesel tractors and diesel equipment. I would think you would be ok to run that.
mine
AFE Stage 2 Intake
PHP F.U. Chip
dads
FB: Tyler Sigmon
big sig is offline
