Sponsored by Discount Tire |
Anyone running 40's?
or 39.5???? i was wondering what kinda fuel milage i'll be seeing as i'm about to move up from a 36 to a 40... with the 36's i'm currently averaging around 13mpg in these winter months... Any input on 40's would be great thanks!
I would say you need some new gears, maybe like a 4.56 or something like that to run those 40's, assuming you havnt changed out already.
i'm running 3.73 right now.... would i not have any power if i didn't change gears or what?
IDK from experience but they say the largest tire to run with a 3.73 is a 35'', someone should chime in. Would you be pulling a lot?
I'm running 36's right now w/ the 3.73s and it pulls fine and is pretty fast for a big *** truck.... but i found some 40" wrangler mtrs for $1000 for all 4 and don't think i can pass that up... but if it's not a good idea i don't think i'll be doing it....
I dont know how large you could run, some one will chime in with more knowledge...
im running 40x17r16.5 ground hawgs and im on stock gears still... only problem you will have is higher egt's... but personally it feels the same as 4:56's cuz my brother had same truck as me and had 40's with 4:56's and he had some lower egt's... but thats only my opinion... you will see a rpm diff but personally no power diff...
also i forgot to tell my mpg lol... i get like 10-12mpg city and when i run to the coast at like 65mph i usually avg 15-16...
Runnin 38's on 3:73,runs fine,13mpg,but I am sure 4:88's would be much better pullin power.
i have 40's also and get 13 or so with stock gears im going to gear but that will be a little bit
