Need New Gears - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 02-22-2010, 12:51 PM
Need New Gears
Hey i just swapped from the 31's to 37's and yes as expected dropped gas mileage havent really noticed driving wise just in the wallet so i figure the best thing to regain that mileage is to swap gears. so currently truck is one in sign. and i want better gas mileage and not over geared let me know what you have done or what you tink is the best
Old 02-23-2010, 04:13 PM
4.10s are closest to stock over ratio. 4.30s are good if you are towing all the time. I'm putting in 4.10s with 38s hopefully when I get my tax return.
Old 02-24-2010, 11:33 AM
it depends on what u plan to do with the truck if ur going to be pulling go with atleast 4:30s if ure just goin to be driving it aroung 4:10s should be okay im goin to 38s and i pull alot so im goin to 4:56s also because the tires im getting are heavy
Old 02-24-2010, 02:52 PM
i had 4.30's with my 37's and loved them.... ill be doing 4.30's on 40's on the new Excursion in the next couple of weeks...
-Raul
Old 02-24-2010, 06:10 PM
whats a reasonable price to pay to have your gears done? I have 40's and i want to ger trying t decide between 4.56 and 4.30
Old 02-24-2010, 06:17 PM
wel most shops charge anywhere from 250 to 400 just in labor per axle to change them out... gears with install kits varry but generally under 300 an axle... so about 1600-2k is what its going to cost to regear your truck
-Raul
Old 02-24-2010, 07:10 PM
did ford ever offfer an axle with 4.10 so like i could swap axles?
Old 02-24-2010, 07:13 PM
yup... and they offered them in 4.30 as well but on the larger trucks
Old 02-24-2010, 07:20 PM
what gears do you have now? 4:10 would work well...4:30 would be much better for towing, but higher RPM's
nice truck
Old 02-24-2010, 10:01 PM
curious on this to? whats the best for mileage on 35's?
