Dually Axle - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 02-08-2010, 03:55 PM
Dually Axle
Are dually axles and single rear wheel axles the same setup just different rims??
Old 02-08-2010, 04:41 PM
No , dually (pick up ) axles are wider and have bigger tubes . Dump trucks/cab and chassis are narrower but I don't know if they are the same as srw trucks.
Old 02-08-2010, 04:48 PM
Duallys are Dana 80's not Sterling 10.5's
I believe
Old 02-08-2010, 04:53 PM
Yea mine is a dana 80 , so was my 2000 , don't know what my 08 was didn't keep it long enough .
Old 02-09-2010, 07:20 AM
Well F250's have dana 80 also is the only difference the rims
Old 02-09-2010, 01:32 PM
No the 250 and 350 SRW have a narrower axle . Also duallyies have bigger axle tubes and axles .
Old 02-09-2010, 01:38 PM
How about the front ends?? could you run a dually rim on the front axle??
Old 02-09-2010, 01:40 PM
wriott
Guest
Posts: n/a
duallys have D80 rears and D60 fronts, SRW have D50 fronts and 10.5 fronts...
this is from 99 to 07
Old 02-09-2010, 01:44 PM
"How about the front ends?? Could you run a dually rim on the front axle??" Yea , you would need the factory dually spacer .
Old 02-09-2010, 01:45 PM
Not even close. The dually rear ends are MUCH bigger, heavier duty.
