Go Back   Ford Powerstroke Diesel Forum > General Topics > Wheels, Tires, and Brakes
Sponsored by Discount Tire
Old 06-30-2009, 02:24 PM
Southpaw Southpaw is offline
1/20/2013
Hub-centric vs. Lug-centric
OK what is the point of having a hub-centric wheel?
I know the obvious answer that most people will say, but as long as you have tapered lugnuts, really what is the big deal
If your lugnuts are tapered and you torque them right, the wheel isn't going to runoff.....
Isn't hub centric wheels just for ease of installation?
discuss....
Old 06-30-2009, 02:37 PM
powerstrokin87 powerstrokin87 is offline
Send a message via MSN to powerstrokin87
I thot they were also to help reduce vibration but my new wheels are not hub centric and i have no vibration. I guess they just help take some stress off the lugnuts too.
Old 07-01-2009, 04:09 AM
HeavyAssault HeavyAssault is offline
Hub centric wheels help carry the load directly on the hub.
Old 07-01-2009, 08:28 AM
Sleeperstroke Sleeperstroke is offline
Hubcentrics are used to point balance a large balanced tire. Its difficult even for the electronic/laser balancers to get the balance completely correct on a big AT or MT tire. Hubcentrics merely take up the slack from that. They work really well, especially for our trucks here. They also help keep the tire balanced as it wears between balance/rotation cycles.
Old 07-01-2009, 08:31 AM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
Exactly.
wriott wriott is offline
BUILT & BROKE BY ME
think about this.... would you trust your lug nuts and bolts to handle 20K lbs or more..... i wouldnt, that is why it is designed with hubcentric wheels and hubs.
Old 07-01-2009, 08:35 AM
Your on the right track but your axle isn't designed to handle 20k lbs in the first place. 4900 lbs on a dually and 2900 on a SRW i believe.
Old 07-01-2009, 08:37 AM
BUILT & BROKE BY ME
smart a$$
Old 07-01-2009, 08:42 AM
smart azz? Usually but not so much this time, I would hate for a reader to see that and think he can load his bed that heavy.
Old 07-01-2009, 08:45 AM
BUILT & BROKE BY ME
true, i ment 20K as a figue of speech trying to make a point. but im still gonna call you a smart A$$
also you have a PM comming....
