Need help with high EGT - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
 1Likes
  • 1 Post By Corey@CNCFAB
post #1 of 8 Old 07-04-2014, 05:58 PM Thread Starter
I have a 1997 F350 crew cab 4X4 auto Tran with gauges, replaced down pipe, 4" exhaust, intercooler, shift kit, baby swamped injectors, upgraded intake, 6 position chip from swamps, large Tran cooler and pan. When I changed the injectors the bearing was ou of turbo so I replaced with a dominator from little power shop.I only get 5-7 pounds of boost and get are 1200 degrees at 60 pulling 5 wheel 15000 lbs. Any ideas how to fix. No leaks or plugged in exhaust.
wnbearhunter is offline
post #2 of 8 Old 07-04-2014, 08:05 PM
Quoted: 27 Post(s)
Starting two threads about the same thing won't yield two different answers....
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #3 of 8 Old 07-13-2014, 12:16 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
assuming your D66 still has the 1.15 housing, swap it out for a 1.0 housing. the usable RPM range is better, boost is built sooner, and EGTs are cooler. you may need to work with you turner as well
also check for exhaust and boost leaks
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is online now
post #4 of 8 Old 08-15-2014, 05:30 AM
EGT's
What's a D66 ? I have an F350, dually. Improved intake, DB tuner, Improved exhaust. My EGT's also run high, although not quite as high as Bearhunter's. I'm looking at a Water/Meth injection from Snow. It's kinda pricey at $850. Do you think there's enough bang for my bucks ? I tow a big 5th wheel camper of about 13-14,000lbs. I'm gonna be spending a couple of months in and around the rocky's this summer and I want to deal with this stuff prior. What's your advise ?
TheJimS is offline
post #5 of 8 Old 08-15-2014, 05:54 AM
Quoted: 759 Post(s)
Jim, the D66 is a modified l99-03 stock turbo.
Check all areas for boost leaks whether it be on the hot side or cold side. I wouldn't mess with the water meth system. One thing to do to lower your EGT's is gut your turbo exhaust housing by removing the butterfly valve in there. Known as the exhaust back pressure valve. It'll lower about 100-200*
TheJimS likes this.
Corey@CNCFAB is offline
post #6 of 8 Old 08-15-2014, 07:18 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The d66 is also a modded 94.5-97 turbo isn't it?
What year is your truck the jimS
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 8 Old 08-15-2014, 09:38 AM
Quoted: 759 Post(s)
yes it is, the 94-e99 is more common to find on the interwebs, but shops modify both the obs and late 7.3 turbos. I shouldve been more specific. Its a modified stock compressor housing to accept a stock 38R compressor wheel.
post #8 of 8 Old 09-02-2014, 04:05 AM
Quoted: 3 Post(s)
Your boost might be a bit low.
However, you did not say what axle you have and the rpm's at 60 mph you are at.
A 15000 pound trailer will create lots of stress, especially at too low an engine speed. You probably are well over the maximum gross weight specified for your truck.
I considered the water/meth, but found it would take a lot of the mix to do much good when towing heavy.
Airstreamer67 is offline
