Towing question - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 4 Old 07-03-2014, 08:38 PM Thread Starter
Towing question
I have 1997 F350 4X4 crewcab upgraded exhaust, gauges, intake, baby swamper, 6pos. Chip, dominator turbo, inter cooler, shift kit for auto tran., larger ran cooler pan and I can only get 5-7 lbs boost. No leaks checked the gauge. Just add the dominator turbo and there is no plugs or leaks. Getting high egt when towing
wnbearhunter is offline
post #2 of 4 Old 07-03-2014, 11:03 PM
Quoted: 28 Post(s)
Did you do a boost leak test? You said no leaks and checked gauge. What gauge are you referring to?
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #3 of 4 Old 07-04-2014, 04:51 AM
jesilvas's Avatar
Quoted: 2 Post(s)
You need to check your boost system for leaks (not just the gauge), and then check for exhaust leaks.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 4 Old 07-04-2014, 11:09 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
You have a boot that's failed or a clamp that's not tight....
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
