cabover camper - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 6 Old 06-12-2014, 05:48 PM Thread Starter
Quoted: 2 Post(s)
cabover camper
I have a 96 lance cabover camper I just got. I have an 06 f250 4x4 cc lb. First off I used some 4x4's to space it up because my cab is tall compared to how they were back in 96. My questions are how much do they move or "wiggle" going down the road and do they ever seem like they are trying to lift? I really need to talk to someone who has used one a lot. Thanks in advanced!
Chad
bigchad93 is offline
post #2 of 6 Old 06-12-2014, 06:53 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
What you might do is get into the camping/rv section and repost your question there. Good guys over there that would love to help if they see the question.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
The Following User Says Thank You to kinnisoj For This Useful Post:
bigchad93 (06-12-2014)
post #3 of 6 Old 06-12-2014, 07:20 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
If you anchor it like youre supposed to it shouldn't move
Sent from AutoGuide.com App
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #4 of 6 Old 06-14-2014, 02:52 AM
Quoted: 58 Post(s)
The amount of movement largely depends upon the terrain. If you stay on road then there is not much, so 2" of cab clearance is fine. If you go off-road at all, then suggest 4" of cab clearance to prevent contact from frame flex or cab movement. The camper itself shouldnt move much, but it can flex during articulation. The cab moves much more due to the rubber cab bushings.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #5 of 6 Old 07-16-2014, 10:47 AM
Parts Jimmy's Avatar
I have a F350 with a Northstar TC. I have added 3 2x4s and three sections of 3/4" plywood over the 2x4s. I have about 3" of clearance over my cab. I have never had an issue and I have clearance lights on top of my cab.
7.3 Power Stroke Diesel, 4R100, 4" MBRP Exhaust, Ford AIC, Motorcraft Air Induction System,
DP-Tuned, AIH Deleted, EBPV Deleted, Bellowed Up-Pipes, Dieselsite Coolant Filter, Bilstein 5100 Shocks, Timbren Overloads, Husky Mudflaps, Hella 700FF Driving Lights, Autometer Gauges
Parts Jimmy is offline
post #6 of 6 Old 07-16-2014, 10:50 AM Thread Starter
Quoted: 2 Post(s)
I am making a better frame to space mine up but as it will sit I too have about 3" of clearance using 4x4's. I made an l shaped anchor out of steel and it slides into receivers I welded on my frame. Everything is welded and steel except for the frame. It
Just seems to move a lot.
