2 broken teeth on my 4.88 ring gear. - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 17 Old 05-28-2014, 03:35 PM Thread Starter
I'm new to this forum and have mainly just read other people posts to learn more about my 6.0 until now.
I was coming home from a camping trip this weekend towing my toyhauler that was about 11,000 lbs. and broke 2 teeth on my ring gear. My truck has quite a few mods on it, but they are mainly for towing durability. I was running a tow tune from innovative and was noticing some pretty rough shifts with the truck jumping forward while shifting. I never had this before and assume this caused some shock loading on my gears that led to the failure. I have already spoke to innovative and they have already sent me their AGG towing tune. Is there anything else I should be looking into changing so I don't break gears again? I only had about 18k miles on the gears. I was thinking maybe a wicked wheel would ease up surging if it was turbo related. If it was line pressure and shifting issue hopefully the new tune addresses it. Any help or input would be appreciated. I dont want to have to get towed and need new gears every 18k miles.
bad269 is offline
post #2 of 17 Old 05-28-2014, 03:47 PM
ZMANN's Avatar
Quoted: 1344 Post(s)
honestly I think your gears had an issue and weren't set up optimally
yes they lasted 18 k but they should be able to deal with what happened
ask whomever does the next set to analyze the wear pattern
also i agree the tow tune needed some help so if the new tune doesn't smooth it out I would try another tuners heavy tow Gearhead /Wildman
and good luck I know getting towed sucks specially when your towing
We Miss you Ronnie
ZMANN is offline
The Following User Says Thank You to ZMANN For This Useful Post:
bad269 (05-28-2014)
post #3 of 17 Old 05-28-2014, 03:49 PM
Teachagmech's Avatar
Quoted: 398 Post(s)
Garage
^^^x2
your gears should have lasted WAY longer than 18k. think of how many trucks there are out there that work their tails off for a few hundred thousand miles.
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
The Following User Says Thank You to Teachagmech For This Useful Post:
bad269 (05-28-2014)
post #4 of 17 Old 05-28-2014, 04:05 PM Thread Starter
Thats what I was thinking. Unfortunately my truck is at the same gear shop for the repair that installed them. I doubt they will tell me if they did something wrong the first time. He said shock loading is what did it. I said I towed the same trailer 2k heavier from Sacramento through Arizona on worse hills with only 3.73 gears for 18 hours each way. The trip it broke on was 2 hours each way.
bad269 is offline
post #5 of 17 Old 05-28-2014, 04:26 PM
ZMANN's Avatar
ask them for the old gears for analysis ( might scare them LOL)
and post some pics maybe someone can evaluate not that it will ever come to them fessing up anything but
I think they are wrong or like you stated "CYA"
shock loading from what you had going on is not catastrophic
i have seen broken gears that deserved to be broken
heck even my own I got side swiped doing 40 and did a 180 then smacked a curb that broke teeth from shock loading LOL
We Miss you Ronnie
ZMANN is offline
post #6 of 17 Old 05-29-2014, 05:51 PM Thread Starter
I just picked up the truck. It actually had 3 broken teeth on the ring gear. He said it was obvious that the gears had gotten pretty hot too. He recommended Redline shock proof gear oil. I have always ran Amsoil. He said they run the Redline in there dragster. Anyone have any experience with the Redline shock proof?
bad269 is offline
post #7 of 17 Old 05-29-2014, 06:04 PM
ZMANN's Avatar
gear oil failure is so rare when u use good names
I do not know what to say about the heat issue he observed being caused by the amsoil
you said He did the gears 18 k ago ? didn't he do the last fill ?
on 08 rear cover would be a nice cheap upgrade and any good oil in the correct spec IMHO
but Red-line has a good rep so I wouldn't be afraid to try it
We Miss you Ronnie
ZMANN is offline
post #8 of 17 Old 05-29-2014, 06:44 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 330 Post(s)
What differential is in this truck? Sterling? Dana? Banjo? Did you see the ring and pinion? Did it look like it had been hot? Guarantee you the pinion depth wasn't set right.
Edit: sorry didn't read sig. Its a sterling
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #9 of 17 Old 05-29-2014, 08:18 PM Thread Starter
I did the last fill. After the 500 break in I put amsoil in it. I even changed it due to age since it was done.The heat observation was a surprise for me running the amsoil and a mag hytec cover.
bad269 is offline
post #10 of 17 Old 05-29-2014, 08:21 PM
ZMANN's Avatar
i think the gears were set wrong and the heat was a result of friction
if there was even any heat issues ?? i kinda doubt it unless you saw anything
but hopefully they got it dialed in this time
We Miss you Ronnie
ZMANN is offline
Tags
gears , surge , torque , towing , turbo
