Do I need a WD hitch....? - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
 1Likes
post #1 of 17 Old 05-15-2014, 09:18 PM Thread Starter
I have a 2004 F350 SRW CCLB. I also have a 21' aerolite TT that I am going to start towing. My question is do I need a WD hitch for the truck and trailer combo? The trailer has a sticker that says it weighs 3300 lbs empty. I hooked it up to the truck this evening to start getting it ready and it dropped the truck rear wheel well height 1 1/2", without anything in the trailer( no water, no personal items, etc) empty like when it came from the dealer. So it will probably drop it more when it is loaded. Will a WD hitch level it out? Should that trailer weight need a WD hitch? Is something else wrong, the truck shouldn't sag with only 3300 lbs?
Would a set of super springs be better? Thanks.
Will.
2004 F-350 Lariat Crew Cab FX4, Dark Grey, T3 Front and Rear replacement bumpers, Fumoto valve, Diamond plate running boards, Zoodad mod, Dieselsite coolant filter w/ ELC, Blue Spring Mod, LED cab lights, Edge Insight CS, SCT SF3, PHP FICM/ECM rollback, Sinister EGR Delete, 6.4 Banjo Bolts, ARP head Studs, Zone Offroad Leveling Kit, CCV Mod, Straight Exhaust, S&B intake, Atlas 40, 295/75R16 BFG,
fishmanwill is offline
post #2 of 17 Old 05-15-2014, 10:17 PM
Rodslinger's B1TCH
your best option is air bag helpers.
a WD hitch is there more for stability than leveling the truck out. when you go over bumps at high speed, the weight of the trailer coming down gets absorbed by the torsion bars instead of pushing the full tongue weight down behind the rear bumper. my brother has blown out multiple sets of rear shocks on his truck while towing a loaded cargo trailer without a WD hitch.
steve604 is offline
post #3 of 17 Old 05-16-2014, 04:25 AM
07upbandit's Avatar
Trailer hitches have weight ratings. They are rated for weight carrying, and weight distributing. There should be a tag on your hitch cross tube. I'm pretty sure the stock hitch is rated for 500# tongue weight and 5000# trailer weight. Once you exceed weight carrying capacity of the hitch you risk hitch failure. You can stick 2 x 4's between your axle and frame to level the load, but you haven't addressed the safety issue. Your trailer is light enough that it doesn't require weight distributing. I sell trailers and would suggest to one of my customers in your situation to try it without for a trip or two. If you notice "porpoising" going over bumps, or trailer sway then it might be time to look into weight distributing. The tongue weight of you trailer setting your truck down 1 1/2" could be a result of soft suspension or a high unloaded ride height. Those trailers are pretty light. Just food for thought
97 F250 HD Ext cab, LB (Sold and missed)
Banks Power Pack
07 F250 CC SB Outlaw
Studs
Black Onyx HG (OK so far)
Sinister EGR cooler
Sinister Oil cooler
Red Head Steering box
07upbandit is offline
The Following User Says Thank You to 07upbandit For This Useful Post:
fishmanwill (05-17-2014)
post #4 of 17 Old 05-16-2014, 05:45 AM
A 21 footer, no, doubt you need anything unless that trailer carries about 500 gallons of water(it doesnt) or is made of solid steel walls and bullet proof.
Your truck shouldn't even know it's back there. You'll see people tow way more than that, safely even, without anything everyday.
Air bags would be the best option overall, and healthiest for the truck, but that really shouldn't sag it that bad. I've done 4 bikes in a single axle trailer, 400lbs each, 1500 trailer, 2 generators(3500w), gas cans, tires, race gear, and 1 bike in the bed of the truck from FL to OH, and it sagged about the same, but no WD hitch, no bags, nothing. It was fine, and definitely "safe", no Oh sh*t moments at all.
2010 Ford F250 XLT ; 5" Diamond Eye DP Back ; 2" Rough Country Leveling Kit ; 18x9 XD Hoss's wrapped in 33 Mastercraft AXT's ; 4" Top Gun Customz Blocks ; SCT Livewire w/ Gearhead Custom Tunes : AFE Stage 2 CAI
madcat6183 is offline
post #5 of 17 Old 05-17-2014, 05:22 AM Thread Starter
The trailer does sit higher then it did from the factory. The hitch is 26" off the ground. I had the trailer raised at the dealer because we camp off-road a lot.
post #6 of 17 Old 05-31-2014, 05:44 AM
Quoted: 2 Post(s)
I would suggest supersprings and a rear sway bar. My trailer alone is 7k pounds...it does not drop much.
Weathertech Floor Mats, Weathertech Window Vents, Valentine One Radar Hardwired, 5th Wheel/Gooseneck Package w/Factory Fifth Wheel, Upfitters, Line-X, Moonroof, Clearance Lights, Block Heater, DeeZee Low Profile Tool Box, Roll N Lock.
mmm635 is offline
post #7 of 17 Old 05-31-2014, 05:52 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I agree with the guys above your probably dont reeley need one but you might look into getting one. I know on my camper that it makes a HUGE diffrence running down the road on how it feels.
I dont need one on mine but I wont run it very far with out hookin it up. And while your at it look at a anti sway control set up. If you pull in any kind of wind you'll thank me later.
steve604 likes this.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
The Following User Says Thank You to kinnisoj For This Useful Post:
steve604 (05-31-2014)
post #8 of 17 Old 05-31-2014, 09:45 PM
Rodslinger's B1TCH
this may have been avoided with a WD hitch
https://www.youtube.com/watch?v=kwOqARlw1EI#t=41
FF to about 40 seconds
steve604 is offline
The Following User Says Thank You to steve604 For This Useful Post:
kinnisoj (06-01-2014)
post #9 of 17 Old 06-01-2014, 04:49 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Steve604 thatnks for that link. Their is some great videos in that!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 17 Old 06-01-2014, 05:50 AM
Jon B.'s Avatar
Nice Turbo.
Jon B. is offline
