bolting fifth wheel slider in intermediate position? - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 5 Old 05-09-2014, 03:44 AM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
I have a slider hitch when in forward position I just barely dont clear 90 degrees, when in aft position if clears with 12" plus. I want to run it into the middle which would be dead over axle and lock it in place. I could either weld the frame to the square tubes (Reese Kwik 20k rails square tube) or drill holes in the middle of the assembly through the frame, through the rails on both sides with 5/8 Grade 8s, or drill holes and use Grade 8 Pins like used to hold the rails to the bed.
Ive towed with it in the forward and aft position and it tows great in both, i am not whatsoever worried about pin versus axle position because as I said I have towed with in the rear position 1000s of miles and probably would continue to do so if I dont bolt it in middle. Just wondering if I am overlooking anything? Always good to bounce ideas of the wealth of experiance in this forum. I think 2 or 4 Grade 8 5/8 bolts would be 10x stronger then the locking pin that drops in the rail and holds the unit in position design from Reese.
Thoughts?
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #2 of 5 Old 05-09-2014, 07:13 AM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
This is what my Elite 20k hitch sits on. It locks full forward or full aft. I would put it in center and put 4 5/8" x 3" grade 8 bolts through the frame of the sliding unit that would go through the rails (horizontal) at the marked locations.
post #3 of 5 Old 05-10-2014, 03:31 PM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
Well I guess I am in uncharted territory. I pinned it where I wanted with 4 5/16 grade 8 bolts. Ill report if there is ever any issue.
post #4 of 5 Old 05-10-2014, 09:49 PM
Quoted: 6 Post(s)
I would think you would be just fine. Those bolts have a massive shear strength.
2006 F250 Lariat FX4 6.0 PSD
Performance: EGR delete, SCT tuned, 5" straight pipe, blue spring, 03' turbo
Other mods: Nathan Airchime K5HA locomotive horns, high idle mod, fog light mod
Videos:
avfrog is offline
post #5 of 5 Old 05-11-2014, 02:33 AM
sixltr's Avatar
What pin box do you have ? There are different pin boxes for short bed trucks that move the pin further forward.
2006 EC Dually 4x4 4.10 Auto
Batmowheel
Sct livewire ts
4" Flo pro exhaust
Cat elc
Bd boot kit
Rancho 7000 shocks
Firestone air bags
Rotella T6, Archoil 9100
PHP Ficm tuner
Studs with OEM gaskets
S&B cold air intake
Sinister coolant filter
Spearco Intercooler
sixltr is offline
