route 66 tires - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 6 Old 05-06-2014, 04:39 PM Thread Starter
the baconator
terryknight's Avatar
Quoted: 150 Post(s)
route 66 tires
Has anyone ever heard of them? Supposedly they have been around since 2011. I just found out about the today while looking for new tires. they offer a trailer tire in 235/85-16 load range G which would be perfect for the GN. it needs at least 2 new tires, so why not four
link
http://www.route66tire.com/
- Tire Business - The Tire Dealer's No. 1 News Source
ebay link to tires
New Tires 235 85 16 Route 66 Payload All Season LT235 85R16" 14 Ply 1st Line | eBay
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #2 of 6 Old 05-06-2014, 07:12 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
eBay link fail,
The first link is a home page of not much,
The middle link says article can't be found,
you gonna try them out?
Let us know
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 05-07-2014, 03:11 AM Thread Starter
the baconator
Quoted: 150 Post(s)
let's try again
ebay link
other link
http://www.tirebusiness.com/article/...load-str-tires
i realize the homepage leaves alot to be desired. i have no idea if i will try them, the fact that i had never heard of them is a little off putting
post #4 of 6 Old 05-07-2014, 02:54 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
If you decide to try the. Out just let us know how you like them
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 6 Old 05-07-2014, 05:02 PM Thread Starter
the baconator
Quoted: 150 Post(s)
will do....
post #6 of 6 Old 06-08-2015, 05:13 PM
Route 66 235/85/R16 Rated G (14 Ply Tires)
Had seen your thread after my tire dealer in Neosho, MO gave me the details and info about these tires. The company webpage has a little bit to be desired. But the tires look great and ride smoother than my older tires (not a lot of miles, had to replace them due to tire rot). If there is interest, I will post pictures of tread, DOM, etc. They now list the tire as a all purpose truck tire (not trailer only).
My reasoning for going from an E to a G tire is due to the type of roads I drive on (mostly gravel, dirt, rough roads), not long distance per say...just getting down to the fishing hole with the family. I have a 1996 Pace Arrow Vision and the E's seemed to always look flat even when inflated max. Found a scale nearby and will get my vehicle weighted. Also, learned that the tag axle is not carrying any weight. The box spring is shot and the prop board had broke (poor man's fix). Will be putting in proper spring or maybe even air suspension.
Tire company in Neosho, MO is Wiseman Family Tire (will be purchased by Granger Family...don't know if they will change name), but they charged $149.95 per tire.
Currently running 90 psi in each tire (max 110) which is near max of my wheels (stamped 95 psi). The ride home was much better...didn't waller around so much (if that is a good term to use). One thing I noticed, was that the only tires that were not tire rotted of the old ones, were the tag axle (possibly due to no weight on them). Otherwise, all same age, same mileage, same sun...same damage.
aflyingsub is offline
