How Much Weight Can Bed Sides Handle---Homemade Sled Deck - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 10 Old 04-29-2014, 06:33 AM Thread Starter
I would like to build a sled deck that rests totally on the bed sides of the truck. It would need to be 102" wide by 84" in length to be able to hold 5 motorcycles with a total weight of about 1200 lbs. I will be adding air bags to the rear axle for stability help.
I currently have a homemade ladder rack on the truck which I will either modify or start over. I want to make the new rack with just the headache portion and the 2x2 angle iron sides. Then the sled deck will slide up on top of the 2x2 angle, which is bolted onto the bed caps with 3-1/2" bolts, and bolt to the side rails. I think with the deck bolted to the rails I shouldn't have to worry about the bed sides tweaking.
Appreciate your thoughts/suggestions.
How Much Weight Can Bed Sides Handle---Homemade Sled Deck-phone-pics-3-12-12-018.jpg
2001 F350 CCSB ZF6
stickk is offline
post #2 of 10 Old 04-29-2014, 06:54 AM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
From an engineering standpoint, because there's so much "surface area" the weight is distributed upon, plus it's mostly in compression, I would think the 1200lbs wouldn't be a problem.
BUT,,,, what IS going to be a problem is where it's located...
You're drastically effecting the CG. That much weight, that high, and you've created a 70mph pendulum
NoRalPh is offline
post #3 of 10 Old 04-29-2014, 07:22 AM
sbluke55's Avatar
Quoted: 528 Post(s)
Garage
I would have support legs that come down and tie into the frame where the bolts for the bed go. No extra holes in the bed and all the weight and load is transferred to the frame. That is a lot of weight that heigh up. Not to mention trying to get them up there when your done.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 10 Old 04-29-2014, 07:26 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I agree with the legs under the middle, but you could also just get a utility trailer
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 10 Old 04-29-2014, 07:33 AM
ZMANN's Avatar
Quoted: 1469 Post(s)
I do not think 1200 lbs is an issue specially since the bed has vertical supports at the front and rear then the wheel wells
we have had lumber racks that support across the bed rails and have loaded thousands of LBS on them between 5/8 drywall and big ole beams
that being said when we pulled the racks and bed liners the bottom of the beds were deformed around the mounting bolts from all the weight LOL
just make sure the across the bed rail is rigid I have seen bedsides bow out due to racks spreading and no tailgate to hold it all together
the center of gravity is a worthy concern however no worse than a cab over or loaded lumber rack IMHO
they sell some cool toppers made for quads to sit on
ps bags mounted at the frame rails aired independently will help sway
We Miss you Ronnie
ZMANN is offline
post #6 of 10 Old 04-29-2014, 07:58 AM Thread Starter
351-The trailer will be a camper, hence the need for the sled deck. A toy hauler is too much $$$$ and I'm not sold on a 5th and a tag behind that.
zmann-I was thinking the same. I think I've had about 1000 lbs on my truck rack all on the drivers side! And some of those slide in campers are over 3k lbs( I know, they sit on the bed floor) but it is still a ton of weight. Friend of mine had a slide in around 2-2500 I think and said there was a huge diff in stability once he installed air bags.
I know it is going to be top heavy so I will have to adjust our speed accordingly. We travel only about 100 mi's to most of our destinations with very little Interstate so keeping the speed down won't offend too many.
Thanks for the replies.
2001 F350 CCSB ZF6
stickk is offline
post #7 of 10 Old 04-29-2014, 10:44 AM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
you should add bars in the middle , car weighs about 1700 pounds , only about 5" of tubing goes into the bed holes , call me stupid but iv done 90 down the freeway with that up there , barley notice its there , this post was just to show having 1200 pounds up there wont hurt anything at all
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #8 of 10 Old 05-02-2014, 08:24 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Thats a pretty crazy setup 897! I need to get me one of those, people would look at my crazy! my car weights 2900lbs though and would kinda make me top heavy!
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #9 of 10 Old 05-02-2014, 08:44 AM
hoofdoctor's Avatar
I see some pretty heavy looking truck bed campers in the back of trucks and I can't say I've ever seen one cause a wreck from being to top heavy??? JMO
SCT 5015 Livewire TS....... Diamond Eye 4" Pipe Cat deleted.........EGR DPF Deleted....... Sinister Intake Elbow........ S&B Cold Air Intake.......
hoofdoctor is offline
post #10 of 10 Old 05-02-2014, 11:01 AM
Quoted: 11 Post(s)
i have seen some stock height 6.0 duallys driving around with my setup , but since there wider it was made for rails like the one in your avatar , really wide and heavy!
-Jeremy
Got A Few Rides...
