Minnesota DOT GCVWR - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
 1Likes
  • 1 Post By strokin-7.3
post #1 of 4 Old 04-13-2014, 08:23 PM Thread Starter
Minnesota DOT GCVWR
Running a theoretical scenario here to Figure out the rules of the road, or open to loopholes you may know of
Currently I am using an f250 with a 24k Goose. I want to avoid a tractor and trailer due to the cost of licencing and insurance(I would use it probably 5k miles tops for 3 quarters)
I am wondering If the MN DOT cares about the manufacturers recommended towing capacity and how the GCVWR is calculated in Minnesota. So If I had a trailer rated for 36k and the f250 having a gvwr of 10k, would I be able to legally gross 46k?
Thanks in advance if anyone can help me out here!
Edit:I should also mention i do mostly intrastate hauls with occasional hauls into SD and Iowa(I hear the Iowa DOT is rough).
Hoop is offline
post #2 of 4 Old 04-14-2014, 02:33 AM
Quoted: 28 Post(s)
Not positive seeing as I'm in GA, but I know here they look at the truck and trailers combined GVWR's and axle weights. So I think you could legally gross 46k provided you don't bust axle weights, which I have a hard time seeing. Not saying I'm within weight limits all the times either.
Barry Smith likes this.
strokin-7.3 is offline
post #3 of 4 Old 04-14-2014, 05:53 AM
jesilvas's Avatar
Quoted: 3 Post(s)
Are you doing this for commercial? If so, you're illegal, and it will NOT be worth your cost for licenses and insurance and yada yada.
Do you know your truck's GAWRs and what it weight empty? I bet you'll overload the truck's rear GAWR as well as it's own GVWR.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 4 Old 04-14-2014, 06:08 PM
StarDriver's Avatar
46,000 with an F250, some lawyer will have a field day with you if you ever get in an accident and if the DOT ever puts you on a scale, you couldn't hire enough lawyers to get you out of that kind of trouble.
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
