Help keep my 7.3PSD cool during towing - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 8 Old 04-12-2014, 04:58 PM Thread Starter
I have a 2003 F250 SD PSD, and when I pul my 33CK it does great except when I keep on the throttle uphill the temp wants to climb rapidly at 2400 RPM. I need some ideas to help keep it cool during long hauls, the transmission temp does fine but the engine temp climbs. Any ideas?
Thanks
m2b1969 is offline
post #2 of 8 Old 04-12-2014, 05:03 PM
Quoted: 5 Post(s)
have you ever done a thermostat, waterpump, or cooling fan clutch? Cleaned your radiator fins? just things to check.
2002 f250 ccsb 4x4, 250/200's,5 inch mbrp,itp boost fooler,regulated return/race fuel system, s&b intake, billet 4r100, swamps idm, lifted 2 inches, leveled, 35inch nittos on 18" s468, mishimoto intercooler, hydra tuning, detroit locker rear, dynomat, not done.........
2006 f350 ccsb 6.0, sct tuner 3015 custom tunes, studded, deleted, exhaust
mastertech79 is offline
post #3 of 8 Old 04-12-2014, 05:07 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 452 Post(s)
Put a 6.0 intercooler and trans cooler in it. Helped me with my fifth wheel
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #4 of 8 Old 04-12-2014, 06:00 PM
1snakedoc's Avatar
check the rad the fins are probably full off trash, get it washed and see what it dose
Matt PAA #117 99.5 F-250 XLT CC SWB 4x4 4R100 Warn M12000 GPR-LED. Foil Delete. 6637. 0.50. AC. Isspro Dual Pyrometer. AeroForce. FRx. HPx. DIY SS Fuel Lines. 03 HeadLights. 4" SS Exhaust. 6.0L Trans Cooler. BTS Tunes. Custom Lighted Tuner. IH Up Pipes. EPBV Delete. AIH delete. Isspro Boost Trans. Van Turbo WW2.
1snakedoc is offline
post #5 of 8 Old 04-14-2014, 06:05 PM
StarDriver's Avatar
Take you foot out of it.
Check your fan to see if it's working properly, you might have to add an auxiliary fan and turn it on when climbing hills.
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
post #6 of 8 Old 04-28-2014, 10:12 AM
7.3 changed to 6.0 cooler
I had my stock trans cooler changed out to a 31 roll trans cooler. Big difference. The trans does not overheat. My problem is that the mechanic also disconnected the trans fluid going into the radiator. What is anyones take on this? He says it gets clogged up if not disconnected. I am thinking of reconnecting it.
Also what is the function of the bypass valve? Some say to take it out.
Thanks Ken
kenwood is offline
post #7 of 8 Old 04-28-2014, 12:02 PM
Quoted: 4 Post(s)
How hot does the engine get in degrees, water and oil. How are you measuring them?
Are you watching preturbo EGTs too (recommended)? If so, how hot are they getting?
About the tranny cooler, it is normally recommended that the oil first run through the factory radiator port then to the auxiliary cooler then back to the tranny. On the other hand, you say your tranny temps are OK as is. How hot does that get in degrees?
Airstreamer67 is offline
post #8 of 8 Old 05-02-2014, 12:38 PM
Gunner
GunnerB's Avatar
Thanks Ken
I would reconnect it to the radiator. While I suppose anything could become clogged it's no more susceptible than your OTA cooler, and I have never heard or seen a documented case where this has happened.
The bypass is there to keep fluid moving in case something does get clogged. It's a safety measure more than anything.
2003 F250 7.3L CC XLT SB
AIS Intake
4.5" ICON Lift
Pre-Pump/Coolant/Transmission Filter
PHP Hydra
6.0L Cooler
ISSPRO EGT/BOOST/TRANS
B&W Turnoverball
Firestone Airbags
Warn Premium Hubs
Cobra 29 LX BT
2002 EX LIMITED 7.3L
DS Trans Cooler
Bilsteins
GunnerB is offline
