B&W Turn Over Ball Problems - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 19 Old 04-02-2014, 05:59 PM Thread Starter
colt32's Avatar
First off, who has B&W and does your truck jolt or buck hauling any thing? Also, does the ball have a lot of play inside the plate? I have had a lot of problems keeping the hitch bolted tight and every since I put it in my truck and it jolts so bad going down the road that I'd swear I was running a flat tire.
colt32 is offline
post #2 of 19 Old 04-02-2014, 06:43 PM
StarDriver's Avatar
I put 80,000 miles on pulling a gooseneck and never had a problem.
Are you having this problem with one trailer or different trailers?
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
post #3 of 19 Old 04-02-2014, 07:13 PM Thread Starter
colt32's Avatar
Well I thought it was just one. I usually only pull our 24ft bar top stock trailer. But since my dad started restoring stock trailers and horse trailers I've been moving a few and they all ride the same.
colt32 is offline
post #4 of 19 Old 04-02-2014, 07:47 PM
Teachagmech's Avatar
Quoted: 408 Post(s)
Garage
Which bolts are coming loose? The tolerance between the ball and socket is rather tight since the round tube is actually what keeps it from moving around, not the square at the top(though it does help). Maybe you're not torquing them tight enough? The only trailer I've towed that bucked really bad was a flat deck Donahue loaded with hay.
I did build my own, but it's reverse engineered from the b&w
Sent from one of the worst apps in the world
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #5 of 19 Old 04-03-2014, 03:16 AM
Quoted: 6 Post(s)
That's why I built mine but welded. Nothing to come loose and sloppy feeling. I would put locktite on the bolts that are coming loose.
2006 F250 Lariat FX4 6.0 PSD
Performance: EGR delete, SCT tuned, 5" straight pipe, blue spring, 03' turbo
Other mods: Nathan Airchime K5HA locomotive horns, high idle mod, fog light mod
Videos:
avfrog is offline
post #6 of 19 Old 04-03-2014, 06:03 AM Thread Starter
colt32's Avatar
Ya there's 6 bolts that hold the plate to the angle iron that come loose and the 4 side ones have been tight end down 2 or 3 times now. I called B&W and there trying to help
colt32 is offline
post #7 of 19 Old 04-03-2014, 06:38 AM
Quoted: 408 Post(s)
Garage
Are you using lock washers? I have grade 8 hardware and split locks on all of mine. Torque them to 90 lb/ft and they shouldn't come loose unless the center section isn't bent straight. If there's a gap, it won't matter how tight you get the bolts, they'll work loose.
post #8 of 19 Old 04-03-2014, 07:36 AM Thread Starter
colt32's Avatar
Yea there all grade 8 with lock washer. I put thread lock on them so I don't think they'll come loose again. I may just put rails in
colt32 is offline
post #9 of 19 Old 04-03-2014, 12:48 PM
Quoted: 408 Post(s)
Garage
well good luck to you. I've never heard of this being a problem.
Did you install or take it in to somebody?
post #10 of 19 Old 04-03-2014, 12:50 PM
upd103's Avatar
Send a message via Yahoo to upd103 Send a message via Skype™ to upd103
That's odd. I've had mine in for a while, and I've never had a problem. My ball fits in the sleeve tight though. Never been loose.
-David-
upd103 is offline
