F250 With 32' Car Hauler - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
 1Likes
post #1 of 25 Old 03-29-2014, 06:01 PM Thread Starter
Irishpilot's Avatar
Well, getting ready for our 2400 mile move to South Carolina and I loaded up the trailer to get a weight ticket. Here is a pic of the truck & trailer without the WD hitch hooked up. I hooking it up tomorrow.
I plan on four extra wide 1,000 lb straps for each car. Any other tips?? Trailer weighs in at 9,200 lbs without luggage. Will get a final weight in a few days.
2000 Crew Cab F250 4x4:
Performance: Bone Stock
Mods: Indash Kenwood DVD/Nav, 08+ power/lighted/heat tow mirrors
Irishpilot is offline
post #2 of 25 Old 03-29-2014, 06:43 PM
1snakedoc's Avatar
i had a trailer just like that before i got a gn, it was a hopper, it was 32' deck, and a 7' hitch. and i had a 2000 f-450 4x4 on it the truck was 9000lbs and the trailer did fine.
turn wide and go slow, make sure the brakes work and you have at lest 1 spare tire.
Matt PAA #117 99.5 F-250 XLT CC SWB 4x4 4R100 Warn M12000 GPR-LED. Foil Delete. 6637. 0.50. AC. Isspro Dual Pyrometer. AeroForce. FRx. HPx. DIY SS Fuel Lines. 03 HeadLights. 4" SS Exhaust. 6.0L Trans Cooler. BTS Tunes. Custom Lighted Tuner. IH Up Pipes. EPBV Delete. AIH delete. Isspro Boost Trans. Van Turbo WW2.
1snakedoc is offline
post #3 of 25 Old 03-29-2014, 06:52 PM
Ontario Trucker's Avatar
That's good advice, be careful & good luck
Gerry..... 2006 F350 Lariat, white
Ontario Trucker is offline
post #4 of 25 Old 03-29-2014, 10:15 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
That's a nice set up, Make sure you have those straps in good spots, good luck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 25 Old 03-30-2014, 05:18 AM
Why would you want to leave Vegas.....
post #6 of 25 Old 03-30-2014, 05:48 AM Thread Starter
Irishpilot's Avatar
Haha, yeah after four years it's time to move on. This can be kind of a rough town, but it is a town like no other!
post #7 of 25 Old 03-30-2014, 05:52 AM
OK thx for the info, good luck in SC
post #8 of 25 Old 03-30-2014, 06:04 AM
c69ss396's Avatar
stop and check your straps every so often....
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #9 of 25 Old 03-30-2014, 06:39 AM
Quoted: 6 Post(s)
Have a safe trip!
2006 F250 Lariat FX4 6.0 PSD
Performance: EGR delete, SCT tuned, 5" straight pipe, blue spring, 03' turbo
Other mods: Nathan Airchime K5HA locomotive horns, high idle mod, fog light mod
Videos:
avfrog is offline
post #10 of 25 Old 03-30-2014, 08:23 AM
SC is NASCAR country, should be lots of jobs there....
As C69 mentioned, every time you stop, check the tie downs
