Gotta ask this towing question - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
 3Likes
  • 1 Post By NYC F-350
  • 1 Post By sealeveloc
  • 1 Post By 351fifty
post #1 of 7 Old 03-26-2014, 01:06 PM Thread Starter
catloaderdude's Avatar
Hello again, talked to a friend who is very knowledgeable with 6.0 powerstrokes but I would like more input. My recent purchase of a 04 F250 6.0, well it has the APR studs, K&N intake, 4" cat back exhast. He said pulling my 6000lb travel trailer should be no probāblem but I ask about the need of a EGT gauge and his answer was I don't really need one.
Thank you ahead for more wisdom.
catloaderdude is offline
post #2 of 7 Old 03-26-2014, 01:11 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Assuming everything other than what you listed is stock, he is right, you don't.
catloaderdude likes this.
Please
You could save the life of a sick child
NYC F-350 is offline
The Following User Says Thank You to NYC F-350 For This Useful Post:
catloaderdude (03-26-2014)
post #3 of 7 Old 03-26-2014, 01:26 PM
sealeveloc's Avatar
Quoted: 19 Post(s)
Just let it cool down a bit before you shut it off after towing or a good romping, and you should be good.
Byron
O6 350 XL
The usual I wanna go fast mods,
maybe a lil more,
maybe a lil less
sealeveloc is offline
The Following User Says Thank You to sealeveloc For This Useful Post:
post #4 of 7 Old 03-26-2014, 02:34 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It's good to have and know what's going on, but not necessary in all situations
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
The Following User Says Thank You to 351fifty For This Useful Post:
post #5 of 7 Old 03-26-2014, 05:43 PM
Quoted: 27 Post(s)
If its a K&N oil filter I'd get rid of it. Just my .02
strokin-7.3 is offline
post #6 of 7 Old 03-26-2014, 06:13 PM
Quoted: 6 Post(s)
^ agreed! If he is very knowledgeable about 6.0s then he should have already told you to go back to the stock donaldson filter. K&N let's much larger particulates into the engine/turbo.
2006 F250 Lariat FX4 6.0 PSD
Performance: EGR delete, SCT tuned, 5" straight pipe, blue spring, 03' turbo
Other mods: Nathan Airchime K5HA locomotive horns, high idle mod, fog light mod
Videos:
avfrog is offline
post #7 of 7 Old 03-26-2014, 06:24 PM
6.0f250firstcar's Avatar
You should be fine with 6,000 pounds. When you get to 10,000 lbs or above it when I'd get a gauges for sure but until then you should be alright as long as you don't hammer it and just use common sense.
Ryan
6.0f250firstcar is offline
