Towing ratings and limits what truck ??? - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
 3Likes
  • 2 Post By dannanw
  • 1 Post By jesilvas
post #1 of 10 Old 02-11-2014, 01:23 AM Thread Starter
Question Towing ratings and limits what truck ???
I am trying to figure out towing options that I might have to stay legal for personal use.
First of all what I have to tow:
Boat trailer aluminum trip axel GVWR #15,000
Trailer weight #1,600
Boat weight #10,500 - #11,500
Now if I bought a truck with a towing GVWR of #11,500 or #12,000 would that be considered over the #26,000 even if real weight is under and warrant a CDL?
I was looking at an Excursion and the most GVWR is #9,200 that I have found. According to ford site that I looked at I would need a dully because of the trailer weight. I know they are strong enough to pull what I want but I want to stay legal because of insurance. I do not pull far about ten miles.
How do all these GVWR combinations come into play with a (bumper) style hitch (non fifth wheel)? I do not know what the actual tongue weight is, maybe #900.
I am looking to buy a tow vehicle and that is why all the questions. I defiantly want a 4x4.
Thank you in advance for any and all help.
Nelson
redmanf1 is offline
post #2 of 10 Old 02-11-2014, 02:42 AM
alaskan155's Avatar
Quoted: 60 Post(s)
gvwr doesnt mean anything,
gcwr is what matters
actual weight of truck and trailer cannot exceed the manufacturers gcwr or axle rating.
and you don"t have to worry about a cdl until total wieght exceeds 26,0000lbs
and a boat at 11500+8200(my truck*for ex., with 2 people and full tank)= 19700lbs
my gcwr on my 02 cclb f250 is 20,000, so i have 300lbs to play with before im illegal.
edit forgot trailer weight, that adds into the equation, so i would be illegal
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #3 of 10 Old 02-11-2014, 04:46 AM Thread Starter
The chart did not paste very good but it looks like the Excursion max trailer weight is 11,000 from this 05 ford chart.
2005 EXCURSION
Maximum Loaded Trailer Weight (Lbs.) –
Axle GCWR Automatic Transmission
Engine Ratio (Lbs.) 4x2
4x4
5.4L SEFI V8 3.73 13,000 6,100
4.10 14,500 7,600
7,200
6.8L SEFI V10 3.73 17,000 10,000
9,600
4.30 20,000 11,000
11,000
6.0L V8 3.73 20,000 11,000
11,000
redmanf1 is offline
post #4 of 10 Old 02-11-2014, 06:15 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
cdl only needed if towing for "proffit"/being hired...look at all the huge RV's 90 year old grandpa's who couldn't pass a cdl phyical
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #5 of 10 Old 02-11-2014, 10:34 AM
jesilvas's Avatar
Quoted: 2 Post(s)
What state are you in?
You need to look at all of it. But most likely, a DOT office will only look at GVWR and GAWRs. I've been weighed before, so that's what happened. GCWR is manufacturer's ratings, but not considered by DOT usually.
Boat trailer: GVWR of 15k. Tongue weight of roughly 25%. 3750lbs is roughly tongue weight. Without actual weights it's all best guess. (I assumed it was a GN/fifth wheel.)
Bumper pull is about 15% tongue weight. 2250 would be rough tongue weight.
You would also need real weights of the trucks to decide if you're over their GAWRs or GVWRs.
Licenses: What state? Texas, a single rig under 26k GVWR needs a Class C. Everyone get's that.
A Class B covers trailers over 10K GVWR or single over 26K GVWR.
Class B is the heaviest, all over 26K GVWR.
Or something like that, I forget, not looking it up right now.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 10 Old 02-11-2014, 02:07 PM Thread Starter
I thought bumper pull is closer to 10%. The boat weighted 10,500 at the factory but can change easy since it holds 260 gals of fuel (1600 #’s). I had the trailer weighted and it was 1600. So I think it is around 13,000 with partial fuel.
In other post it is stated that the GVWR is what is most important, so I really don’t know. That is why I am trying to get correct answers.
I think if we use 1400 as a tongue weight for a pull trailer it will be good. I cannot get any weights as it is snowed in…
I have been using a 1500 AWD with air bags but it is not legal and takes experience to use. The front tires try to spin if you do not take off just right. The 6.0 gas engine has amply power to pull for what I am doing but just will not handle the weight correctly.
I do not really care about fuel mileage as the truck will mainly be used close to home. I have been looking at the 2002-2006 f350 4x4 with miles in the 150k-200k miles to keep the price down..
Thanks again
redmanf1 is offline
post #7 of 10 Old 02-11-2014, 03:44 PM
jesilvas's Avatar
Quoted: 2 Post(s)
GCWR is more for the manufacturer's ratings.
GVWR and GAWR will be what anyone with scales will watch, because all those numbers are legally written on each vehicle.
10%-15% is average. RVs usually say 15% so that's what I'm using, and it helps you over compensate.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 10 Old 02-11-2014, 04:20 PM Thread Starter
Ok, so if I have a GVWR of 9900 GAWR front 5200 GAWR rear 6830. Let’s say this crew cab 8 ft. bed SRW 4x4 truck weights 7000, so is that a payload of 2900? If so with a tongue weight of 2000, trailer 15000 would it be legal? As long as not over 900 in truck people, cargo, ect.
redmanf1 is offline
post #9 of 10 Old 02-11-2014, 04:53 PM
jesilvas's Avatar
Quoted: 2 Post(s)
That math is correct as long as rear GAWR isn't overloaded
LSeven likes this.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 10 Old 02-11-2014, 05:21 PM Thread Starter
Yea fun............
How much weight would overload a GAWR rear 6830???
What are you saying, don't put all 900 in the trunk. lol..
redmanf1 is offline
