Which Truck? - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 18 Old 02-01-2014, 09:53 AM Thread Starter
98csvt's Avatar
Which Truck?
I am getting an F-250 or 350, but will the SRW and DRW make a big difference in pulling a 48ft gooseneck? I am wanting SRW so I can do other things with the truck but I am not sure if I need DRW. I will be hauling my 98 GT and 97 Cobra along with tools and such. I run HPDE with Nasa and will be hauling long distances. Sorry if y'all get these posts a lot, my dad used an 06 250 for a 20 foot enclosed which is a paper weight to these trucks. Thanks, Ben
1998 Mustang GT
IG: whitelightning98gt
2006 F250 CCLB KR FX4 Bulletproofed, SCT Livewire TS, KC billet compressor wheel. 1.9 60' @TX2K15
1997 Mustang Cobra Track Toy
1965 2+2 Fastback Project car
Dad's Tow Vehicle: F150
Old Tow Vehicle: 06 F250 intake and tune.
98csvt is offline
post #2 of 18 Old 02-01-2014, 11:11 AM
Depends on how often you will be towing? If it's often I'd go dually if not more than a couple times a year I'd go F-350 single rear wheel.
Tjmaxx is offline
post #3 of 18 Old 02-01-2014, 11:58 AM
Dually, if you tow it often.
Check your weights.
letitsno is offline
post #4 of 18 Old 02-01-2014, 12:01 PM
Talked with a state trooper in WI, they will make you unhook and then you have to get right truck to tow trailer or hire someone.
letitsno is offline
post #5 of 18 Old 02-01-2014, 12:40 PM
Sam Hain's Avatar
That big of a trailer I'd want a DRW.
Sam Hain is offline
post #6 of 18 Old 02-01-2014, 01:12 PM
Quoted: 6 Post(s)
48' gooseneck and long distances? I vote DRW.
2006 F250 Lariat FX4 6.0 PSD
Performance: EGR delete, SCT tuned, 5" straight pipe, blue spring, 03' turbo
Other mods: Nathan Airchime K5HA locomotive horns, high idle mod, fog light mod
Videos:
avfrog is offline
post #7 of 18 Old 02-01-2014, 01:14 PM Thread Starter
98csvt's Avatar
I keep leaning to the DRW option because of the size, but I won't be towing all of it but a couple of times, I will usually pull it with one 'stang and racing equipment at I would guess 16,000 pounds? That's why I think a SRW will be ok with some towing mods.
1998 Mustang GT
98csvt is offline
post #8 of 18 Old 02-01-2014, 01:18 PM
Quoted: 6 Post(s)
How many miles do you figure while your towing this 48' trailer? No "towing mods" will give you the stability and safety of a DRW truck.
Videos:
avfrog is offline
post #9 of 18 Old 02-01-2014, 02:08 PM
Sam Hain's Avatar
"towing mods" won't put more tires on the ground and thats what you need pulling that kind of weight.
Sam Hain is offline
post #10 of 18 Old 02-01-2014, 02:26 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Nuttin like havin that fat azz behind you when your pullin some weight around.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
