Trailer Size for Hauling SD's - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 21 Old 01-24-2014, 03:46 PM Thread Starter
Hello,
I looking at a trailer to haul a crew cab long bed. I looked up specs online and they showed a width of 79.9 and I am not sure if that is the body or wheel track, is a 82"-84" wide trailer deck sufficient? What size trailer deck will accommodate a crew cab long bed lengthwise? The Ford site posted almost 22' length but most commonly available trailers are 20' is it okay for front and/or rear overhang? Will a 10K GVWR suffice for capacity which leaves about 7400-7600# plus 1K tongue weight of about 8400-8600 payload. Is it okay for the rear wheels to sit on dovetail or is it preferable for a straight deck trailer?
Thanks
15 F250 XL 6.7L CC LB 4x4 (temp work truck)
03 Excursion Ltd 6.0L ARP studs/HG, turbo back exhaust, K&N CAI, EGR delete, 6.4L banjo bolts, blue spring, coolant filter, IDP tunes, SCT Livewire (regrettably sold)
08 Jayco 31 BHDS G2
96 Regal 258 Commodore
rowekmr is offline
post #2 of 21 Old 01-24-2014, 03:57 PM
F250SixOH's Avatar
I don't see a problem with the rear wheels on the dove tail. You definitely are going to want a WD hitch. At 10,000 gvwr you are right at it with a CCLB and trailer weight.
I'm not sure what the width is between the wheel wells but you could always do something like this.
http://www.kaufmantrailers.com/car-t...amond-tilt-car
F250SixOH is offline
post #3 of 21 Old 01-24-2014, 05:45 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I put a crew cab long bed in a 28x8.3 trailer, it was a 4x4 86 f350, Dana 60's are same width with obs and sd rite my trailer was enclosed however
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 21 Old 01-24-2014, 08:44 PM
StarDriver's Avatar
Originally Posted by rowekmr View Post
Hello,
Thanks
I'd look for a trailer with 2- 6000# or 2- 7000# axles, If it's got stock wheels it may fit on a trailer like the Kaufman. Always leave extra capacity on your trailer, it will pull better, be safer and last longer.
I once put a F250, 4X4 crew cab, long bed inside my enclosed, it almost touched both wheelwells as it came in.
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
post #5 of 21 Old 01-24-2014, 09:03 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I had to crawl out the center rear window when I loaded that f350 in mine, had about another foot in front and maybe the same behind it
Trailer was 28 feet long almost seemed to small
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 21 Old 01-28-2014, 04:53 AM Thread Starter
Thanks for all the advice. I went out there and looked at a 10K auto hauler and a 14K equipment hauler. I am not sure which one I prefer but also considering a used 2 car (bumper pull) hauler.
08 Jayco 31 BHDS G2
rowekmr is offline
post #7 of 21 Old 01-28-2014, 03:10 PM
StarDriver's Avatar
I'd skip the 10K, it's not heavy enough, the 14k is better, with the 2 car, you'd better be really careful where you put that truck, if you don't balance it right, you're gonna need some clean underwear.
post #8 of 21 Old 01-28-2014, 03:31 PM
F250SixOH's Avatar
X2! That could be a bad situation if it wasn't loaded right.
post #9 of 21 Old 01-28-2014, 03:38 PM Thread Starter
Yeah I would bring my tongue scale with me. I have read that 10%-15% is the optimum tongue weight, any other suggestions for loading?
08 Jayco 31 BHDS G2
rowekmr is offline
post #10 of 21 Old 01-29-2014, 06:06 PM
StarDriver's Avatar
What are you pulling this with?
The Following User Says Thank You to StarDriver For This Useful Post:
BRAD6160 (01-30-2014)
