gooseneck trailer help! - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
 1Likes
post #1 of 16 Old 01-23-2014, 03:30 PM Thread Starter
1snakedoc's Avatar
im looking at getting a goose neck trailer to tow tucks f250-f550. I buy them in bad shape and tow them back to fix and sell. to get a 550 on a trailer it has to be +7' wide. i would like a low deck not a deck over is this realistic. i have found some that are 6' 10" wide 20' long but that puts the dual wheels right on the trailer wheels. if i get a low deck what length if a deck over what length do you recommend.
i have used a 24' 6' 10" that a f250 will fit but very tight, no way a dually will fit as the front lugs are over 7' wide. the 24' is longer than i need but is is nice to have some room to balance the load, as a 550 with a long bed vs 250 short bed needs different spots to be loaded right for the tongue weight.
what size and what weight trailer deck over are low deck. i will be looking at used trailers so i'm open to many options.
i will also be putting a winch and battery on it so i will need room for it.
Matt PAA #117 99.5 F-250 XLT CC SWB 4x4 4R100 Warn M12000 GPR-LED. Foil Delete. 6637. 0.50. AC. Isspro Dual Pyrometer. AeroForce. FRx. HPx. DIY SS Fuel Lines. 03 HeadLights. 4" SS Exhaust. 6.0L Trans Cooler. BTS Tunes. Custom Lighted Tuner. IH Up Pipes. EPBV Delete. AIH delete. Isspro Boost Trans. Van Turbo WW2.
1snakedoc is offline
post #2 of 16 Old 01-23-2014, 03:54 PM
F250SixOH's Avatar
You could get a low trailer with drive over fenders
F250SixOH is offline
post #3 of 16 Old 01-23-2014, 04:09 PM Thread Starter
1snakedoc's Avatar
will drive over fenders hold up a 550? as with a 18'-24' trailer the wheels will have to rest on them the hole trip. and the front wheel lugs are too wide and low to pass most low trailer fenders i have seen.
post #4 of 16 Old 01-23-2014, 04:18 PM
F250SixOH's Avatar
Hmm I have seen some pretty beefy drive over fenders before but I'm not sure on how much they are rated for. Why not a deck over with dovetail?
post #5 of 16 Old 01-23-2014, 04:27 PM
I would recommend a 24' deck over with a dove tail
mashthegas is offline
post #6 of 16 Old 01-23-2014, 04:35 PM
Quoted: 36 Post(s)
drive over fenders are just that. to drive over- not to park on and be cinched down on top of. a deck over with dove tail will be good- I use one. they are not too tall and top heavy when loaded as some think.....
gwilkrrs is offline
post #7 of 16 Old 01-23-2014, 04:50 PM Thread Starter
1snakedoc's Avatar
im not apposed to a deck over i just like the lower ones for easier loading as most of the time the trucks will not run.
what weight rating do you think 14k? i have cdl's so that is no problem if i need to go higher.
post #8 of 16 Old 01-23-2014, 04:53 PM
44magnum's Avatar
Quoted: 2 Post(s)
I have a drive over fender 24' trailer with 7K axles (GVWR 14K) of the few I looked at this was the only one with really sturdy drive over fenders, I wouldn't be afraid to park a truck on them if need be. It had no trouble hauling my oliver 1850 (weight 10K) Its an off brand trailer so I don't know where else you can buy them. Check out this other thread. Tiger trailers?
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #9 of 16 Old 01-23-2014, 05:03 PM
F250SixOH's Avatar
A heavy duty winch with a couple of deep cycle batteries is a must when doing what you will be doing.
post #10 of 16 Old 01-23-2014, 06:00 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
A deck over with a dove should be fine, especially since your adding a winch as is
avfrog likes this.
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
