Gooseneck adapter - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 12 Old 01-17-2014, 09:37 PM Thread Starter
Quoted: 3 Post(s)
Gooseneck adapter
Hey guys,
Anyone have any experience with camco gooseneck adapters?
Finally bought another trailer and am considering them for my hook up, just wanted some opinions on installing and how they work, also any issues you've had!
P-rot
Here it is....
Item
NEW TRUCK
'17
Crew cab
F350
Dualy
4x4
King Ranch
B&W 5th wheel hitch
91 gallon in bed fuel tank
SOLD
02 7.3
CC SB
4x4
P-rot is offline
post #2 of 12 Old 01-27-2014, 12:24 PM
sabarnes's Avatar
I use an Anderson Ultimate 5th wheel to gooseneck http://www.andersenhitches.com/Produ...k-version.aspx
takes a lot of the chop you get from the right angle of the kingpin to gooseneck adaptors. I've towed about 3000 miles with the Anderson on well neglected US 56 and US 54. Heavy trackor trailer traffic and the Anderson does well. Firend I work with has traveled the same route with his gooseneck adapter and gets "kicked" the whole way.
Just another option to look at.
sabarnes is offline
post #3 of 12 Old 03-03-2014, 02:08 PM
Teachagmech's Avatar
Quoted: 408 Post(s)
Garage
sabarness,
is the inside of the ball coupler lined with UHMW plastic? I don't see how else an aluminum coupler could be grease-less
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #4 of 12 Old 03-03-2014, 02:30 PM
Vannnce's Avatar
Quoted: 13 Post(s)
Have you ever used an adapter before? i dont think much of them in comparison to a regular fifth wheel hitch. they really suck if you use them a lot, or for long hauls IMHO
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #5 of 12 Old 03-03-2014, 02:45 PM
Quoted: 408 Post(s)
Garage
i have the GN already, and i'm certainly not a long trip road warrior. the few times a year i'd use it, i'm willing to go for the adapter. I kinda like the ultimate from anderson but its a whole darn adapter kit. might as well get a companion. i know a lot of people really don't care for adapters in general
post #6 of 12 Old 03-03-2014, 03:42 PM
sabarnes's Avatar
No its greaseless. Same as a standard ball hitch. I'm sure you could grease the ball for added piece of mind. I've had my fifth hitched with a fifth wheel receiver and the Andersen. To me the Andersen rode nicer and was easier to connect and disconnect. It took a little convincing to go with it. But most of the farm trucks run gooseneck for the work trailers and the Andersen for their fifths around here. I was glad to find an alternative to the kingpin to gooseneck adapter. The right angle to the gooseneck ball wasn't ideal to me based on research and reviews personal and read. People I know have said they buck bad. The Andersen feels like a fifth receiver. My first trip with it was 1100 miles in 2.5 days. 2 weeks later the same for a return trip.
sabarnes is offline
post #7 of 12 Old 03-03-2014, 04:10 PM
Quoted: 408 Post(s)
Garage
Their pics show it black inside, wasn't sure what it was.
Sent from one of the worst apps in the world
post #8 of 12 Old 03-03-2014, 04:20 PM
Quoted: 408 Post(s)
Garage
FWIW it looks like the best thing out there for a short bed. Clamps down tight, keeps the same pull height and let's you use the GN ball in your truck regardless of the mfgr
post #9 of 12 Old 03-03-2014, 04:33 PM
sabarnes's Avatar
Yeah never looked up into it but it does look like the same coating that their greaseless balls have.
That's what became my issue. It's kind of hard to have gooseneck mounting brackets, fifth wheel mounting bracket and future install of air bags all connected to the frame in about the same area.
sabarnes is offline
post #10 of 12 Old 03-03-2014, 05:53 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Reese ISRs #30035 and air bags should not interfere. B&W frame plates and bags might, however.
4R100, 2wd
330,000 + miles
jesilvas is offline
