Frustrating.... - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 17 Old 01-02-2014, 01:11 PM Thread Starter
GreenF350's Avatar
Frustrating....
I am looing at picking up a toy hauler and have been researching this for quite a bit. It needs to have at LEAST 5k lb cargo capacity and at least 18' in the "cargo area". All of this and I would like to tow it with my 2000 F-350 SRW.
What's frustrating is that technically, I can tow more trailer (sort of) with a bumper pull than I can a gooseneck/fifth wheel set up, knowing dang well that the gooseneck/fifth wheel would tow better and not exceed my GAWR, but in the end my GCWR is the limiting factor.
I can get a 32' tag that will weigh in WELL under 10k, say around 7k or I can get a gooseneck that will weigh JUST under 10k empty, probably about 9,900 or so for the same space on the "floor". My truck is rated at 20,000 GCWR and 9,900 GVWR. That means I'm limited to 10,100lbs trailer weight...on an F-350. Seriously!?! WTF? I refuse to get rid of my 7.3, I've considered getting a dually F-350 with the 7.3, but in the end, it's GCWR is still only 20,000lbs. My RAWR is 6,800 and change and while I haven't had it on the scales to measure actual rear axle weight, I figure I have enough leeway for 3,000lbs of pin weight easy. That enough pin weight for 15,000lbs.
I know the newer trucks have ridiculous ratings with dang near the same brakes/axles, etc, but how in the heck is everyone towing around these huge triple axle RV's and not getting their butt handed to them by the DOT/cops? What am I missing? I don't want to pull the trigger on a $50,000 trailer to not be able to tow it anywhere.
-Aaron
2000 Ext. Cab F350 SRW, 6" Skyjacker lift on front/8" BDS Springs on rear w/NO blocks, 37x13.50 Nitto Mud Grappler's, Aftermarket Front Bumper
-Always More Stuff Coming!
GreenF350 is offline
post #2 of 17 Old 01-03-2014, 06:03 AM
gotta_gofast's Avatar
Quoted: 62 Post(s)
Honestly, a lot of people who tow beyond the weight rating of their truck simply don't know or understand that they are. You walk in with YOUR truck and the RV salesman is happy to accept commission on what ever trailer he can sell you. An honest one will pull your vin and recommend trailers within your tow rating.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #3 of 17 Old 01-03-2014, 06:30 AM
ynpmoose's Avatar
Quoted: 7 Post(s)
You need to find your curb weight. If your GVWR is 9900 (think max weight with bed full of payload), your actual curb weight is probably around 6000 empty. This means you could tow 14000 and be under the 20k GCWR.
SOLD - 2003 Excursion 6.0L 4x4
ynpmoose is offline
post #4 of 17 Old 01-03-2014, 06:32 AM
Quoted: 6 Post(s)
I bet there are a lot more over weight than you would think. Around here I think they focus more on what weight your registered for, not so much the weight ratings of the vehicles.
2006 F250 Lariat FX4 6.0 PSD
Performance: EGR delete, SCT tuned, 5" straight pipe, blue spring, 03' turbo
Other mods: Nathan Airchime K5HA locomotive horns, high idle mod, fog light mod
Videos:
avfrog is offline
The Following User Says Thank You to avfrog For This Useful Post:
Heavy_GD (01-04-2014)
post #5 of 17 Old 01-03-2014, 08:32 AM Thread Starter
GreenF350's Avatar
I haven't been across any certified scales that I know of, but I have been across scales at two different scrap metal places and I can tell you that my truck weighs right around 8,000-8,200 "unloaded" with fuel and me inside according to those two scales. I guess it's the lift and tires and heavy duty bumper. I do have some "junk" in the toolbox, but I'd say only a couple hundred. I guess it all adds up. I wonder how much weight I would lose if I went to a 4" lift and 35's. It would probably get under a gooseneck a bit better like that anyway...Hmmm.
-Aaron
post #6 of 17 Old 01-03-2014, 11:12 AM
new7.3strokin's Avatar
I don't know what state your in man but here in maryland DOT only checks weight for commercial vehicles....so if your just hauling a rv or toy hauler your exempt. In maryland you have to be in a commercial capacity for them to get you. But I know every states different
2001 F-250 lariat 4X4 - sold
2006 F-350 Lariat FX4 CCSB -
ARP Studs
Edge Insight CTS W/ EGT
MBRP 5'' turbo straight
S&B Air Intake
EGR delete
Ficmrepair.com Rebuild
PHP Atlas 40
Blue Spring
XDP Coolant Filter
Riffraff Boot Kit / Metal Pipe
Sinister Diesel intake elbow
2010 tailgate w/step
Harley Headlights
Plenty more to come........
HTML Code:
new7.3strokin is offline
post #7 of 17 Old 01-03-2014, 12:42 PM
jetjock15's Avatar
Quoted: 113 Post(s)
I've ran my trailer through near every state, (only havent been NE of PA)there not checking. My CGVWR is 26.5 put I've been over it plenty. On a side note my trailer is a weekend warrior cr3905 it's got 6k load carry and 18.5 before first obstruction and then is still 60" wide for another 10 feet. I get a car in and couple quads.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #8 of 17 Old 01-03-2014, 01:21 PM
Quoted: 17 Post(s)
I know the feeling man, your weight is probably right. My Excursion weighs about the same. From what I've read(again read so its kinda hear say) if you should get into an accident where someone is seriously hurt the insurance company & Law will more than likely look into what your weights are. The insurance could deny the claim & the law enforcement may file charges. Trying not to be a Debbie downer but you may want to look into that stuff. I myself am getting ready to buy an enclosed trailer, then make rudamentary living quarters in the front & space for the jeep in the back. I do wish we could re-rate the trucks for a heavier load.
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #9 of 17 Old 01-03-2014, 07:45 PM Thread Starter
GreenF350's Avatar
This was my main concern. I see/hear/know of people hauling WAY more than the trucks are rated for all the time. I have a neighbor that does demolition work and he grossed over 30k with a idi 7.3L on more than one occasion. I've heard the same thing about an accident or whatnot. I have no intention of getting in one, but like to C.Y.A. if you know what I mean. I wonder if it has ever happened to anyone?
I'm kind of doing the same thing you are talking about, only I'm not as handy with stuff like that as I am with mechanical things. I've been looking for a used ATC, Featherlite, Intech trailer.....setup like I want, or I MIGHT consider buying new if I settle FOR SURE on what I want. Unless I get a bumper pull, I will be looking for something aluminum.
-Aaron
post #10 of 17 Old 01-04-2014, 06:18 AM
jetjock15's Avatar
Quoted: 113 Post(s)
GCVWR "legally" is determined by rear springs, gear ratio, drive ratio (trans and Tire size), and brake capacity. If you are towing anything with any of those items changed you could feasibly be liable. Just points to ponder. Any trailer with living quarters and 5k+ cargo capacity is going to be heavy, probably tripple axle. When you start looking you will see most the standard toyhaulers are rated at 2-3k carry capacity and two 6 or 7k axles are limiting factor.
