Airbags that don't reduce ride quality and travel?? - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 17 Old 12-31-2013, 04:37 PM Thread Starter
DTL
DTL's Avatar
After my first heavily-loaded towing trip yesterday, I'm searching for a set of airbags. I'm very happy with the way the truck rides right now and I spend a lot of time off road for work and play. I've used Firestone air bags in the past, but the shorter "pancake" style bag doesn't have much range of motion. Is there anything else out there that will still help alleviate some of the sag when loaded heavy, but not degrade my nice ride quality or off-road suspension travel?
Thanks!!
DTL is offline
post #2 of 17 Old 12-31-2013, 07:00 PM
StarDriver's Avatar
Thanks!!
Kelderman, but it won't be cheap.
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
post #3 of 17 Old 01-01-2014, 10:57 AM
MuddyATV24's Avatar
I went with Hellwig bags. They mount differently than the firestone and air lift bags, so the off-road capabilities are a bit better. I have flexed my truck pretty good a few times and the bags handle it great. I usually keep about 15lbs of air in the bags and the ride seems to actually be a bit better for my truck.
2001 F-350 Lariat CCLB, 7.3L, ZF6-speed, Manual hub conversion
2" Procomp leveling Kit, Stock wheels with 295/75/16 Toyo AT II's
Front and Rear Ranch Hand Bumpers
MuddyATV24 is offline
post #4 of 17 Old 01-01-2014, 11:11 AM
ZMANN's Avatar
Quoted: 1789 Post(s)
chuck these on and travel won't be a problem nor will ripping a bag and not to mention having to unbolt the bag if your working on the suspension
Daystar's NEW Air Bag Cradle - YouTube
as far as bags I suggest the outboard mount that sits on the spring vs inside the spring and on the axle
We Miss you Ronnie
ZMANN is offline
post #5 of 17 Old 01-02-2014, 09:26 AM
AllGo'N'Show's Avatar
Nice road they are driving on Very cool cradle will keep that in mind!
'16 F450 6.7L Lariat Ult. .:. Tow-Rig
'08 F350 6.4L XL .:. Gone to a new home
Alradco .:. H&S+GH .:. RCD .:. PDR .:. S&B .:. aFe .:. Absolute .:. Fluidampr .:. Toyo .:. Black Rhino
Enjoy horrible service, sub-par quality and made in China product? Mishimoto is your one stop shop!
AllGo'N'Show is offline
post #6 of 17 Old 01-02-2014, 10:37 AM Thread Starter
DTL
DTL's Avatar
Thanks for the links and the suggestions. That Daystar deal looked pretty interesting and so do the Hellwig bags. I'll let you guys know what I end up doing.
DTL is offline
post #7 of 17 Old 01-02-2014, 12:29 PM
Paul's Powerstroke's Avatar
Quoted: 2 Post(s)
I've been looking at the Airlift Loadlifter 5000 Ultimate that has a jounce inside the bag to replace the one you removed when installing air ride which will let you air down the bags to basically 0 psi and not worry about bottoming out and pinching the bags and should give a good range of motion.
Actually, I'm purchasing these real soon and price point is pretty good. Autoanything.com has them for 336.42
2016 F-350 6.7 Lariat Platinum DRW Shadow Black
2015 Puma Unleashed Palomino 351-THSS 37' 5'er Toyhauler
"Just put that hammer down and give it hell" - Jerry Reed.
Paul's Powerstroke is offline
post #8 of 17 Old 01-02-2014, 02:10 PM Thread Starter
DTL
DTL's Avatar
The Airlift bags and that Daystar locating cup/cradle might be a pretty slick combination.
Wasn't there a TSB out about the rear sag on the F250s? I thought I read something about Ford replacing the 2" blocks with 4" pieces for free. This sound familiar to anyone else?
DTL is offline
post #9 of 17 Old 02-14-2014, 08:39 PM Thread Starter
DTL
DTL's Avatar
Just an update: I ended up going with the AirLift airbag kit and the Daystar airbag cradles. There was a problem, however. The normal amount of weight my truck carries (toolbox + transfer tank) had the bags packed down so far, the truck rode like crap. I ended up removing the lower airbag bracket and cutting off the bumpstop ear from the leaf spring block. I used a generic axle mount bracket to mount the Daystar cradle directly to the axle. Now, at static ride height, the bag floats about 1" above the cradle. The truck rides just like stock, but as soon as it starts to take on some load and squat down, the bags contact and take up the slack.
Name:	airbag bracket 1.jpg
DTL is offline
post #10 of 17 Old 05-27-2014, 07:50 PM
andys08's Avatar
I have firestone bags and the cradles what did you use to fill the whole on the bottom of the bag if I use the supplied bolt it will hit the bolt that mounts the craddle to the bracket
2004 6.0 6spd,475hp southbend clutch,sct livewire custom tunes done by brians truck shop,5in straight, leveling kit ,egr delete,traction bars,arp studs. (Sold)
2011 6.7 lariat ccsb tinted,air bags with daystar craddle,Titan fuel tank, mini max with custom mount,5th wheel hitch,hids,icon 4.5in lift in front and dealers full leafs in rear,2wd valence,stock lights pulled apart and painted, all other lights tinted,
andys08 is offline
