2001 Puller - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 6 Old 12-21-2013, 03:33 AM Thread Starter
2001 Puller
Ok need some advice from people who know. I have a 2001 long wheel base f250 4x4. It has a 3 or 4 inch body lift running 315's. 5 inch exhaust with a tuner, tons of power. I want to turn it into a solid puller. Thinking about dropping body down and running 285's. Any suggestions? Is there a good brake up grade? Fuel mileage is terrible with present tires and a good load. Any advice is welcome.
freebirdfishin is offline
post #2 of 6 Old 12-21-2013, 11:35 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Custom tuning, intake, exhaust, and you should have a good rig, what type of loads and what kind of weight are you trying to pull? What type of trailer are you using (or going to use) some of that may help
What kind of puller, like a trailer or a sled?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 12-21-2013, 04:05 PM
Quoted: 6 Post(s)
Stock tire size for one.
2006 F250 Lariat FX4 6.0 PSD
Performance: EGR delete, SCT tuned, 5" straight pipe, blue spring, 03' turbo
Other mods: Nathan Airchime K5HA locomotive horns, high idle mod, fog light mod
Videos:
avfrog is offline
post #4 of 6 Old 12-21-2013, 04:13 PM Thread Starter
I don't plan on pulling anything over 15,000. 21000 GVW Goose Neck. 35 foot boat. Thinking about puttiing a set of dual wheels on the rear.
post #5 of 6 Old 12-21-2013, 04:15 PM Thread Starter
Don't plan on anything real heavy, 15000 max. 35 foot boat about 8000/10000 lb. I was thinking about putting a set of duals underneath the rear.
post #6 of 6 Old 12-22-2013, 09:31 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Mite wanna find a Dana 80 rear then Kause it's a Dually axle
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
