Electric trailer brakes and snow - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 9 Old 11-05-2013, 05:24 AM Thread Starter
Soledad's Avatar
Garage
I've never owned a trailer that was large enough to have electric brakes and the wife and I will be towing a Wells Cargo 7x16 (7000lb) fully loaded for about 1500 miles. Anyway, I was wondering, if while you are towing and hit really bad winter weather, do you leave your settings alone on the brake controller or do you lower the gain way down so the trailer brakes don't lock up? We probably won't hit any snow or ice but I thought I'd better ask just in case.
Thanks!
Shawn
2006 F-350 XLT FX4 SCLB 6.0L | TTY head bolts | stock EGR and cooler | blue spring FP mod | PHP Atlas 40 FICM tune | ScanGauge 2 & GlowShift 3-in-1 gauge (Boost/EGT/FP) | PMM coolant filter kit | Flo~Pro 4" turbo back w/muffler | stock tune
Soledad is offline
post #2 of 9 Old 11-05-2013, 08:25 AM
mor4wd's Avatar
If it were me I'd set the gain when I start the trip with the load in the trailer and not touch it. If the gain is set correctly then you shouldn't have problems locking the brakes up on ice. If they do lock up then you'll most likely be locked up in the tow vehicle also.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #3 of 9 Old 11-05-2013, 02:36 PM
Quoted: 6 Post(s)
^ I agree. I would do the same.
2006 F250 Lariat FX4 6.0 PSD
Performance: EGR delete, SCT tuned, 5" straight pipe, blue spring, 03' turbo
Other mods: Nathan Airchime K5HA locomotive horns, high idle mod, fog light mod
Videos:
avfrog is offline
post #4 of 9 Old 11-05-2013, 05:11 PM
StarDriver's Avatar
What they said.
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
post #5 of 9 Old 11-06-2013, 07:13 AM Thread Starter
Soledad's Avatar
Garage
Ok cool! Thanks.
Soledad is offline
post #6 of 9 Old 11-16-2013, 10:25 AM
jetjock15's Avatar
Quoted: 113 Post(s)
I've towed heavy up and down the ALCAN in winter many times - pure ice. Go slow, brake early, and memorize and rehearse how to grab the manual brake while keeping eyes on road. If the trailer starts to jackknife, only way to save it to go full brake on trailer with manual control and release brakes on truck, let the trailer straighten out the truck. Best advice is go slow and slow way way early.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #7 of 9 Old 11-18-2013, 03:29 PM
hauled many large RVs out cleveland in snow storms and crazy weather. as everyone else said, set it up so you feel the trailer brakes, but they arnt doing the braking for you. if your locking up tires, you have it too high. all the trailer brakes have to do is assist the truck brakes. if they are tugging on you when braking, they too high.
7.3l DRW F350 4x4. stock, with exception of Airbags on rear, bilstein all around and 26k 5th wheel hitch. K&N filter for good measure.
dont try this at home kids!
Unclebobsuncle is offline
post #8 of 9 Old 11-22-2013, 12:27 PM
Quoted: 244 Post(s)
jetjock is on the right path with using trailer brakes to pull out of a jackknife. however you want to avoid locking up the trailer, and sending the whole shebang for a loop. any modern brake controller works off inertia, so it should only brake enough to stay straight behind truck if set correctly.truck ABS comes on=less inertia trailer brakes release. while recovery is important, just plain avoiding the whole scenario by driving slow enough, looking far enough ahead to anticipate events, so that emergency maneuvers are not needed AKA driving defensively is even better
2005 F350 srw Crewcab lariat. 6.0 diesel
nitrogen is offline
post #9 of 9 Old 11-22-2013, 12:48 PM
jetjock15's Avatar
Quoted: 113 Post(s)
Lol, by correct path you mean I kept a 20k trailer and 8k truck on the road for over 3k miles of straight sheer black ice (Yukon/Ak) two different occasions lol - I sure did. By the way I also chained up the front axle of the trailer going down the steep hills. On my first trip I ran studs on truck and trailer, on second trip I did not run any studs. Studs on trailer worked amazing on the ice, all the weight I guess.
