5th rails and gooseneck height - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 14 Old 10-28-2013, 02:48 PM Thread Starter
salnazzaro's Avatar
Quoted: 25 Post(s)
Ok so I didn't get the factory in bed hitch in my 2013 and have been looking at the Reese custom fifth wheel rail kits, we're looking at getting a fifth wheel camper so that will be fine but I also want to get a gooseneck dump trailer and was wondering if the gooseneck hitch that attaches to the rails will be too high for a trailer, I only added 1" higher rear blocks to my 350 and etrailer says it adds 4-6" of height. Just wondering if anyone knows the answer to this. Thanks!
2015 f350 cclb platinum...5% tint, Anzo smoked mirror lights, recon clear cabs, tgc 2.5" spacers, carli adjustable track bar, icon 5" rear blocks, Firestone riderites, B&W goosneck, line x, rancho 7000s, Fuel Mavericks wrapped in Toyo MT's, No Limit stage 2 cold air intake, 4" flo pro straight pipe, Sct w gearhead tunes, hideaway LEDs
salnazzaro is offline
post #2 of 14 Old 10-28-2013, 03:34 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I have the rails in mine and I will measure. It does raise the ball some.
Do you not have an adjustable trailer neck?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 14 Old 10-28-2013, 03:41 PM Thread Starter
salnazzaro's Avatar
Quoted: 25 Post(s)
I don't have a gooseneck yet I just want to make sure the setup I mentioned will be ok height wise, I see a lot of the necks are 32-39 inches
post #4 of 14 Old 10-28-2013, 03:56 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Oh you'll be fine. Just get a trailer with an adjustable neck.
OR get this - Gooseneck to 5th Wheel Plate King Pin Adapter Pipe Hitch Trailer Coupler 30 000 | eBay
So you don't have to keep changing hitches and it's so much easier to hitch a 5th wheel.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 14 Old 10-28-2013, 04:15 PM Thread Starter
salnazzaro's Avatar
Quoted: 25 Post(s)
Ok thanks I just wanted to be sure about the height, I've been tossing up the rails or the factory underbed system but bang for the buck is gonna win I think! Thanks
post #6 of 14 Old 10-28-2013, 05:19 PM
jesilvas's Avatar
Quoted: 3 Post(s)
With the under bed pucks, idk how you can get a GN to hook up
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 14 Old 10-28-2013, 05:27 PM
Quoted: 6 Post(s)
I just went through this. Here is what i ended up having to do to level my horse trailer.
DIY gooseneck hitch
Post #7 shows a pic of my rails and new ball installed. More than enough room for my 5th wheel. Pic of it further down that thread on page 2 or 3.
Mine are reese rails, and the rail kit is in the way of most aftermarket gooseneck underbed kits. I bought the Reese drop in gooseneck ball (the goose). It put the ball 4" higher than the hitch I built.
Note: I have stock tire size on factory 20" wheels. No lift.
2006 F250 Lariat FX4 6.0 PSD
Performance: EGR delete, SCT tuned, 5" straight pipe, blue spring, 03' turbo
Other mods: Nathan Airchime K5HA locomotive horns, high idle mod, fog light mod
Videos:
avfrog is offline
post #8 of 14 Old 10-29-2013, 05:44 PM
1snakedoc's Avatar
my brothers truck 99 250 cclwb 4x4 has a goose neck ball on 5th rails he has to put the hitch all the way in to make it work right as it raises the ball 4.75" from the bed.
Matt PAA #117 99.5 F-250 XLT CC SWB 4x4 4R100 Warn M12000 GPR-LED. Foil Delete. 6637. 0.50. AC. Isspro Dual Pyrometer. AeroForce. FRx. HPx. DIY SS Fuel Lines. 03 HeadLights. 4" SS Exhaust. 6.0L Trans Cooler. BTS Tunes. Custom Lighted Tuner. IH Up Pipes. EPBV Delete. AIH delete. Isspro Boost Trans. Van Turbo WW2.
1snakedoc is offline
post #9 of 14 Old 10-29-2013, 05:55 PM Thread Starter
salnazzaro's Avatar
Quoted: 25 Post(s)
See that's what I'm afraid of the added height with the gooseneck hitch on the fifth wheel rails, the flush reese elite hitch might be a worthy investment then
post #10 of 14 Old 10-29-2013, 06:21 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I wouldn't worry, it's not a huge issue.
Also, can you get a GN ball for the Elite system?
4R100, 2wd
330,000 + miles
jesilvas is offline
