trailer wiring (brake) question - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 17 Old 10-26-2013, 05:49 PM Thread Starter
Quoted: 35 Post(s)
so i got a newer trailer and have some questions. i have another trailer and everything works fine- new trailer is an o6 econoline truck is an 08 f350. question is- when the trailer lights are plugged in the factory brake doesnt lite up on the truck, i tested the parking lights and the flashers and they seemed ok- left may have been slightly dimmer but it was very sunny so i am unsure-
i am sure the trailer harness is the issue but i will test the truck plug in the am----
any suggestions? thanks
gwilkrrs is offline
post #2 of 17 Old 10-26-2013, 06:55 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Like you're thinking, bad connection on the trailer side.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 17 Old 10-26-2013, 08:23 PM
Quoted: 6 Post(s)
Has to be in the wiring it sounds like.
2006 F250 Lariat FX4 6.0 PSD
Performance: EGR delete, SCT tuned, 5" straight pipe, blue spring, 03' turbo
Other mods: Nathan Airchime K5HA locomotive horns, high idle mod, fog light mod
Videos:
avfrog is offline
post #4 of 17 Old 10-27-2013, 04:37 AM Thread Starter
Quoted: 35 Post(s)
thanks- I slid the in dash brake controller bar over and it lit up so I don't think the fuse was blown...........
gwilkrrs is offline
post #5 of 17 Old 10-28-2013, 03:36 AM
If your ""new trailer" ia an '06 check the bulbs.
I JUST had the situation w/ my '07 Hudson where the bulb had "white crud corrosion" built up on it's base. A few swipes of copper cleaning pad on the base and socket and it was like new.
'88 Ford 7.3 E350 Customized Maxivan
'09 VW JSW TDI (up to 47MPG highway)
'02 F350 DRW 4x4, 7.3 PSD, CC
tractors-'07 Kubota B7610
'95 Kubota M4700
gemniii is offline
post #6 of 17 Old 10-28-2013, 03:44 AM Thread Starter
Quoted: 35 Post(s)
So I put I tester into the truck end plug- all checkeed out ok but the brake lights- when brake pedal pushed the light on the tester showed rt and lft lights but not lit on brake.... Maybe that's ok? Never used the tester before. Will check fuses later and bulbs- the brake box doesn't lite up when plugged into trailer harness but does lite up when finger activated so possible fuse 33 for trailer brake module but unlikely-
gwilkrrs is offline
post #7 of 17 Old 10-28-2013, 04:48 AM
jesilvas's Avatar
Quoted: 2 Post(s)
The TBC needs to see resistance to "know" brakes are there.
It's in the plug of the truck or trailer wiring. Most likely trailer wiring.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 17 Old 11-04-2013, 10:40 AM Thread Starter
Quoted: 35 Post(s)
ok- I am stumped. I have all lights, running, turn, and brake lights. the blue wire(brake) is hooked to the blue terminal on the trailer plug end... I checked the wires by hand and didn't see any breaks or bad spots... but the trailer brake controller doesn't sense the trailer.... any suggestions? thanks
gwilkrrs is offline
post #9 of 17 Old 11-04-2013, 11:53 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Bad magnets maybe?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 17 Old 11-05-2013, 04:51 PM Thread Starter
Quoted: 35 Post(s)
good call- hadn't thought of them-- will check soon. thanks!
gwilkrrs is offline
