this might be a dumb question - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 5 Old 09-23-2013, 01:50 PM Thread Starter
i have an 03 f250 6.0 crew cab lariat with 4in suspen. lift and i have a goose neck. i want to get a 3 in body lift. what will i have to do to get the goose neck to work? it is an under the bed gooseneck. thanks for the help also does anyone have an idea of what size tires this would fit and what outset i would need so it doesnt rub?
ddlwfo94 is offline
post #2 of 5 Old 09-23-2013, 02:11 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Do do a body lift, the hitch is on the frame so it will not be as high as the bed, and with a body lift you get a a lot of body roll
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 5 Old 09-23-2013, 02:17 PM
codyryan07's Avatar
A body lift isn't worth the hassle on a diesel.. if you want to lift it, do a proper suspension lift.. you're going to be looking at relocating intercooler, fans, radiator, and everything of the sort just to gain 2-3 inches a body lift would give you..
since you're leaf springs, you can easily gain around 2inches with all sorts of options like new hangers, spring packs, or rearched springs..
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
post #4 of 5 Old 09-23-2013, 03:58 PM Thread Starter
if i lift the back with spring packs how do i lift the front
ddlwfo94 is offline
post #5 of 5 Old 09-23-2013, 04:02 PM
codyryan07's Avatar
The same, or you could do a hanger/shackle lift and not sacrifice any ride quality. You may need a longer pitman arm too, but they're roughly $50-100 from a few vendors on here.
Cody Ryan
4" RC lift
rebuild coming soon
