10"+ drop hitch for 10,000+ lbs??? - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 12 Old 09-02-2013, 02:12 AM Thread Starter
SS14PSI's Avatar
So I have a 02 F350 Dually with a 6" lift and 22.5's. For my car trailer, which sits pretty low, I keep my Rapid Hitch at the bottom (10" drop). For my 14' Wells Cargo trailer, the Rapid Hitch is about 3-4 notches from the bottom.
I'm looking at buying a 30'+ bumper pull toy hauler RV, specifically a Weekend Warrior FS3000, which may get well over 10k lbs loaded. The Rapid Hitch is rated to 10k lbs. what kind of hitch can I get to pull beyond 10k lbs?
02 F350 Dually 7.3L- 22.5's, 6" lift, intake, exhaust, etc.
68 Prostreet Camaro- 540ci BBC, Tubbed, 9". etc.
02 Hayabusa- 1464cc Muzzy's Big Block and some spray.
SS14PSI is offline
post #2 of 12 Old 09-02-2013, 02:10 PM
I think what your looking for is weight distribution style hitch and your going to need a drop shank for it so try here. They have a great selection of weight distribution style hitches and also offer several different drop shanks for them.
Weight Distribution Accessories and Parts | etrailer.com
2008 F-350 Lariat TRCCSB Lifted, Tuned, and Deleted
2003 Mach1 Bassani, 4.10s, pro5.0, bama tuned
thnderchcken is offline
post #3 of 12 Old 09-02-2013, 10:09 PM
Quoted: 97 Post(s)
Feedback Score: 3 reviews
I run a 10 inch drop with my toyhauler. Its a Reese and it does pretty good.
2006 F250 Carli 4.5" Pintop, Carli LT airbags, Top Gun Customz dual steering stabilizer, 4.30 gears Toyo MT 37's, Powermax, SCT X3 w/ Matt's 8k Tow tune, BPD 53 volt FICM, DC Power 185 alt, PMM coolant filter with Rotella ELC, Edge Insight CTS, MBRP 4", Line X'd bumpers, grille, and tonneau cover
villestrip is offline
post #4 of 12 Old 09-02-2013, 10:11 PM
Quoted: 97 Post(s)
Also my trailer is 33.5 feet long from hitch to the rear of the trailer.
post #5 of 12 Old 09-02-2013, 10:27 PM
BIG Laing's Avatar
OUO makes drop receivers that are stronger then any drop hitch I have ever seen.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #6 of 12 Old 09-02-2013, 10:29 PM
Quoted: 97 Post(s)
Yeah but does it help with weight distribution and sway control????
post #7 of 12 Old 09-02-2013, 10:37 PM
BIG Laing's Avatar
It drops the receiver hitch 11.5" so you can use a regular weight distribution / anti sway hitch. So yes it does both.
post #8 of 12 Old 09-02-2013, 11:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Gotta pik of this ouo set up? Sounds pretty sweet
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 12 Old 09-03-2013, 12:01 AM
BIG Laing's Avatar
Ask and ye shall.... some famous quote
post #10 of 12 Old 09-03-2013, 12:33 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Definitely go with a weight distribution hitch because the tongue on that Weekend Warrior is very heavy, and it sits pretty high, so you won't need nearly as much drop.
I have 5" lift and 35's and tow a FS2600, and I only need about 3-4" drop.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
