How important is a level trailer? - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 13 Old 08-31-2013, 07:22 PM Thread Starter
Quoted: 6 Post(s)
So really, how important is a level trailer running down rode? My new horse trailer sits about 3-4" higher in the front than the rear. It's a 22' gooseneck. I have it adjusted as low as it will go, but it's still not quite level.
So how much better would it actually be if it were perfectly level loaded? Ride any better maybe?
2006 F250 Lariat FX4 6.0 PSD
Performance: EGR delete, SCT tuned, 5" straight pipe, blue spring, 03' turbo
Other mods: Nathan Airchime K5HA locomotive horns, high idle mod, fog light mod
Videos:
avfrog is offline
post #2 of 13 Old 09-01-2013, 05:02 PM Thread Starter
Quoted: 6 Post(s)
Guess I could just post a pic. So, any thoughts or leave it alone?
Videos:
avfrog is offline
post #3 of 13 Old 09-01-2013, 05:18 PM
ngaraiderman's Avatar
Looks damn near perfect to me man?!
Is the 4" difference empty? Throw 4-6 horses and the front full of tack and I bet the 4" goes away?
I think its good.
Nice looking setup by the way
ngaraiderman is offline
post #4 of 13 Old 09-01-2013, 06:02 PM Thread Starter
Quoted: 6 Post(s)
Thanks bud. Ya 4" is empty, but it doesn't move any with 3 horses in it. My hitch is an above bed ball, so I would have to install an under bed ball or cut the trailer to get it any lower. So, I'll probably leave it alone. Haha
I'm just picky I guess. Everyone always says the closer to level to better, but didn't really know what difference it makes being perfect.
Videos:
avfrog is offline
post #5 of 13 Old 09-01-2013, 07:01 PM
I don't think you could tell the difference in only 4". Should pull really good being that close to level
post #6 of 13 Old 09-02-2013, 06:44 AM Thread Starter
Quoted: 6 Post(s)
Right on. Thanks!
Videos:
avfrog is offline
post #7 of 13 Old 09-02-2013, 05:45 PM
1snakedoc's Avatar
my brother truck is the same way. he has a gooseneck plate that hooks to the 5th wheel rails so it sits higher then normal. and his trailer is 3-4" higher in the front and it pulls fine even with 10,000lbs on it.
Matt PAA #117 99.5 F-250 XLT CC SWB 4x4 4R100 Warn M12000 GPR-LED. Foil Delete. 6637. 0.50. AC. Isspro Dual Pyrometer. AeroForce. FRx. HPx. DIY SS Fuel Lines. 03 HeadLights. 4" SS Exhaust. 6.0L Trans Cooler. BTS Tunes. Custom Lighted Tuner. IH Up Pipes. EPBV Delete. AIH delete. Isspro Boost Trans. Van Turbo WW2.
1snakedoc is offline
post #8 of 13 Old 09-02-2013, 11:38 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The reason for everyone wanting perfectly level is so that the tires wear even, an the weight is better distributed over the axles, that much rake is negligible to the point, but gonna be a huge pain to get perfect, especially being a gooseneck, set up looks great tho and I'm sure it hauls just fine
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 13 Old 09-03-2013, 12:49 PM Thread Starter
Quoted: 6 Post(s)
Thanks for the input guys. I will say I'm very impressed with how it pulls compared to my 14' bumper.
Videos:
avfrog is offline
post #10 of 13 Old 09-03-2013, 01:37 PM
Trigger01's Avatar
You might gain an inch or so if your ball came through the bed instead of on top. Our trucks sit rather high so it's kinda difficult to make the gn sit level unless we lift our trailers. My trailer and truck have matching rake. After buying my 08 and hooking up the trailer I wished I would have bought on with the smaller wheels and tires. A friends 08 dually sits several inches lower than mine because of wheel tire size.
2008 F-350 Lariat 4X4 CCSB
Trigger01 is offline
