Towing mpg's - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
 1Likes
post #1 of 19 Old 08-13-2013, 11:31 AM Thread Starter
Towing mpg's
I recently traded a Mustang I had for a 31 foot Coachman camper trailer. YES!!! Family is going to have killer camping trips with rain storms not ruining a weekend. We just took our very first trip with the camper to Garner State Park. I have two 7.3L Powerstrokes my work truck is a F350 4x2 and my personal truck is a slightly lifted 4x4 with 315/75R16 All Terrain tires.
To my horror I was averaging 7.5 mpg most of the way on my F250. I was doing about 60-65 and was trying to keep RPM's at 2k but sometimes the tranny would downshift and I would have to back off let it upshift and ease back on the pedal.
I did notice a slightly better economy on one particular tank full when I filled at a truckers diesel pump which gave me 9.31 might have also been a less hilly section of road but I couldn't be sure.
I am calculating using the FuelLog app.
Now for the questions. Is fuel economy this low normal for these trucks? I know my F350 does much better, it can do hours of highway with no stops. What can I do to improve it? It is nerve wrecking driving Texas back roads not knowing when the next gas station will be. How do I keep the tranny holding at 2000 going up a hill without downshifting? Am I driving the truck right?
As comments come in I will probably have more questions.
'99 Ford F-350 dually, Crew Cab 4x2 w/ 7.3L (Totaled- rebuild coming soon)
'01 Ford F-250 Crew Cab 4x4 shotbed w/ 7.3L
7.3Leader is offline
post #2 of 19 Old 08-13-2013, 11:55 AM
Truck is 100% stock?
Let it breathe. Get an exhaust and intake for it. Also get a chip so it has the power and doesn't want to downshift. Those should help you get better MPG.
Also is your speedo adjusted for your 35s?
zillafreak is offline
post #3 of 19 Old 08-13-2013, 11:59 AM Thread Starter
It has an air intake but that is it. No calibration for tires. Not even sure what size in inches they are.
post #4 of 19 Old 08-13-2013, 12:02 PM Thread Starter
A quick Google of 315/75R16 gave me size 37.7 tall and 15.5 wide.
post #5 of 19 Old 08-13-2013, 12:07 PM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
There's you're main problem. You're 60-65 is probably more like 68-75. A regear and tunes would be a must imo
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #6 of 19 Old 08-13-2013, 12:29 PM Thread Starter
Regearing sounds awfully expensive. The truck came with these tires and as it is they are showing a little age with small cracks on the sidewalls. I don't really mind downsizing when the time comes to buying new tires. What make, model and size would give me a good highway drive?
post #7 of 19 Old 08-13-2013, 12:48 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Down shifting is good actually, keeps you from lugging and creating a low boost high egt situation
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 19 Old 08-13-2013, 12:49 PM
If they're old and cracking that time has come. Going down to smaller tire will help your fuel economy. Also your calculated mpg isn't accurate since the tires are a different size, unless the app you're talking about uses gps for your miles driven?
alradco is offline
post #9 of 19 Old 08-13-2013, 01:14 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
First off congrats on the camper. I see your down in South East TX,if you ever plan on heading up into Colorado give me a shout!
Have you thought about the MPGMAX water methonal set up? Wouldnt take long to pay itself back.
And ya Im not real pleased with how often I gotta fill up with my 2005. I talked with a local welding shop and they will custom biuld me a tank that will fit under my tool box in the back for around $200. Ya it dosnt help out the mpg's none but at least I get the peace of mind knowin how much fuel I got.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 19 Old 08-13-2013, 01:18 PM
blue99stroker's Avatar
Quoted: 270 Post(s)
315/75/16's are a 35/12.5 inch tire. your speedo is going to be off.
since you have the intake done thats a plus.
now just get a 4 inch exhaust, some custom tunes. and gauges and your set.
egt and trans temp are a must, boost if you want
custom tunes will help with mpgs, trans shifting because a good tow tune makes a world of difference, and of course more power
and if you experience turbo surge just get a new billet compresor wheel from bd, riffraff, dieselsite.
and if you experience high trans temp while towing look into a 6.0 trans cooler or tru cool max from dieselsite.
that should net some better mpgs, better shifting, and more power
and if you want a little smaller tire go with a 305 or 295 instead of the 315's.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
