Trailer brake disconnect - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 2 Old 06-22-2013, 09:09 PM Thread Starter
frdbronco8's Avatar
I have searched but have not found an answer but I have found that it appears to be a common problem. I have an 05 with the built in TBC. Occasionally whle traveling with the trailer it beeps and shows "trailer disconnected" on the screen. Other than tracing all the wires from the truck to the trailer randomly has anyone heard of something specific to look for?
Thanks
frdbronco8 is offline
post #2 of 2 Old 06-23-2013, 11:18 AM Thread Starter
frdbronco8's Avatar
I dug a little deeper and found that the trailer wire that connects to the truck had damage to it. The black wire was cut about 3/4 through and the previous owners had just wrapped it in tape. I fixed it with a butt connector and heat shrink and will hope that does the trick. I see that the black wire is for the 12v charging and so I don't know if that would have caused the TBC to show disconnected off and on like it did.... The blue wire is for the brakes and it appeared fine....
