Removing Gooseneck Ball - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 11 Old 06-18-2013, 03:19 PM Thread Starter
Hey guys, just got this truck from a dealer and can't quite figure out how to remove the ball from the bed. It has a hole next to it, and both the ball and this plate with the hole are both a little loose. What am I missing?
alternativeoffroad is offline
post #2 of 11 Old 06-18-2013, 03:35 PM
Njstroker91's Avatar
Drivers side fender well is there a lever to pull out I have a Reese on my truck and there is a lever to release the pin.
Sent from AutoGuide.com App
2006 f350 eclb 6 speed, powermax, billet compressor wheel, valair dual disk, 4in to 6in cat stack, afe magnum force stage 2, airdog 150, xdp sump, zoodad mod, sinister coolant filter, gauges egt oil temp and fuel pressure, cfm carbon fiber and metal cold side tub, blue spring, bpd ficm, moto metal 959 18x9 wrapped with cooper at3, custom shift knob from lilpooh, Polk audio all the way around, dashboss for monitoring
Njstroker91 is offline
post #3 of 11 Old 06-18-2013, 03:38 PM Thread Starter
No lever :/ I'm baffled!
post #4 of 11 Old 06-18-2013, 03:41 PM
Mine was a bw I'm sorry. On the plate on the frame see if it has a brand name or something and try out google maybe come up with something. It's possible that it isn't a turnover ball.
post #5 of 11 Old 06-18-2013, 04:43 PM Thread Starter
I tried that, couldn't find anything. I'm gonna do some more looking and fiddling around with it
post #6 of 11 Old 06-18-2013, 04:46 PM
SuperCrutyPS's Avatar
Quoted: 296 Post(s)
Garage
Shooting in the dark here, but is there anything through the hole that you can push on to release the ball?
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #7 of 11 Old 06-18-2013, 05:10 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I got a good one, you tried putting some wrenches and turning it? I had a similar hitch the ball was a screw in type
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 11 Old 06-18-2013, 05:16 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Looked at yours again then looked at mine, try looking at these piks I'm not sure your hole is full cut out
Just put a pry bar or something in that hole and pull it up the ball falls into it, it lays flat
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 11 Old 06-18-2013, 11:09 PM
44magnum's Avatar
My guess is you have one like that ^^^^^ and someone didn't cut the hole big enough to let that flap come up, when they installed it. If that's the case you'll have to somehow cut the hole big enough to get that flap up so you can fold the ball out of the way.
What year is it this on? Also get under your truck and see if there is a pin or something holding the ball in place.
2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5 PMF traction
Please collect and message me Shell, Rotella oil cap codes aka "my miles matter" I'm trying to save up for a hat or something.
44magnum is offline
post #10 of 11 Old 06-19-2013, 06:00 AM
F250SixOH's Avatar
Biggest thing is to get under the truck and check it out.
F250SixOH is offline
