My M101 trailer “repair” - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 8 Old 06-11-2013, 07:37 AM Thread Starter
Lonesome7.3's Avatar
Quoted: 2 Post(s)
When I got this trailer it was thoroughly trashed. It was so bad I thought about just scrapping the whole thing. To start off with it only had one hub. I tracked down a hub and put some good tires on it and replaced all the bearings and seals. But, it still was not road worthy. The brakes were gone and the mechanism on the tongue that engages the brakes was scrap. The internals were rusted out and broken beyond repair. So, I just parked it in the corner of the yard and tossed my scrap in it. I finally drug it up front and started working on it recently. Pictured below is what I have accomplished so far.
Lonesome7.3 is offline
post #2 of 8 Old 06-11-2013, 07:58 AM
buckels's Avatar
Send a message via AIM to buckels Send a message via MSN to buckels Send a message via Yahoo to buckels
Nice I cant wait to see where this build goes!
Drew
99 SD 6SPD manual
AFE Intake
Diamond Eye 4" turbo back exhaust
Wicked Wheel Gen2
PHP Hydra tunes by Bill
If you live in WA or OR check out these links.
buckels is offline
post #3 of 8 Old 06-11-2013, 08:05 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
looks good!!!!!!!! subd!
2000-7.3L is offline
post #4 of 8 Old 06-11-2013, 12:32 PM Thread Starter
Quoted: 2 Post(s)
I have the new tongue peice tacked together now. I still have a few holes to drill then I can finish weld it.
post #5 of 8 Old 06-11-2013, 12:34 PM
2000-7.3L's Avatar
Whyd you take that toung off to put a ball on it?
post #6 of 8 Old 06-11-2013, 12:39 PM Thread Starter
Quoted: 2 Post(s)
That big 75 pound hunk of steel is scrap. The inside is way too far gone to mess with. That trailer would have come of the hitch and killed some one had I tried to use it. I went with the ball mount because at first it appeared to be simpler. Now I am committed but I wish I used a lunette instead.
post #7 of 8 Old 06-17-2013, 07:17 AM Thread Starter
Quoted: 2 Post(s)
Made a little headway. This is just mocked up for now so I can drill the holes I need. I will tack it into place then pull it and finish weld it.
post #8 of 8 Old 07-10-2013, 06:02 AM Thread Starter
Quoted: 2 Post(s)
I have not had much time to work on this trailer lately. But I did finally pull it around front so I can weld it. I have to knock the dust off my Miller first though.
